Help Please Wire And Connector Identification
2 replies to this topic
#1 Majormallock
Majormallock
  • Just Joined
  • 34 posts
Posted 17 November 2020 - 07:17 PM
Hi, putting my restored mpi back together, a couple of labels have gone astray during storage. In the engine bay, first picture in of a brownish/ orange wire of moderate size the is sheathed plastic and fabric loose covering, as if it heat protection it at the front o/s by the starter motor, no connector, can't see anything it will reach other than solenoid but that already has 2 connection's. 2nd picture is right by the horn n/s inner wing. It will reach approx 4 " from that being part of the same loom. Same connector as rad fan but thats already catered for on a post central of the car on the rad itself. Listing this as a last resort. Thanks in advance Attached File  20201117_190907.jpg   35.79K   2 downloadsAttached File  20201117_190810.jpg   44.64K   2 downloads
#2 Itsaminithing
Itsaminithing
  • 852 posts
  • Local Club: Not One Worth Mentioning
Posted 17 November 2020 - 08:41 PM
Same connector as the rad is the easy question,  Japanese Minis had a side mounted rad, UK Minis had front mounted so Rover just made one loom that fitted either variant.
(you'll also find a thick red wire from B7 fuse going up to the roof for the optional electric fabric sunroof).
Not sure on the brownish/orange wire, poss for the starter motor (it should have three wires, one black, one brown, & one red).
#3 xrocketengineer
xrocketengineer
    Rocket Man
  • 1,637 posts
Posted 17 November 2020 - 09:48 PM
If it is brown, it looks like it broke at the fusible link splice joint SJ7 per the wiring diagram, which would be missing together with the eyelet terminal, C823-1/C178-1. This circuit feeds the front fog lamp relay fuse.
Edited by xrocketengineer, 17 November 2020 - 09:53 PM.
