Edited by Minigman, 17 November 2020 - 05:50 AM.
Wheel Bearing Retaining Clip / Spacer
Posted 16 November 2020 - 11:58 PM
Posted 17 November 2020 - 12:14 AM
There is no C clip in any wheel bearing.
there was a seal spacer used on the older cars both drum and disc but this was dropped from the later cars and is perfectly reusable anyway so is not and never has been, as far as I am aware, in any bearing kit.
Posted 17 November 2020 - 12:21 AM
Just to clarify, these are cooper 998 drive shafts / flanges (not the pot joint or hardy spicer with 7.5”)
So if I don’t have this spacers I don’t need to be concerned with locating any?
Just push the seals up to the bearings?
Edited by Minigman, 17 November 2020 - 12:33 AM.
Posted 17 November 2020 - 12:55 AM
Nope leave a gap. But I don’t think it really matters.
Posted 17 November 2020 - 07:37 AM
As Nick mentioned, no.
The Outer Seal is flush or can be pressed a but further in by 2 mm and the Inner Seal goes in to where the taper lead in finishes
Posted 17 November 2020 - 12:27 PM
I’ve actually found a couple of the spacers now. But they are quite thin compared with others I’ve seen. Mine are only 2mm ish wide and ones I’ve seen in the past have been more like 5 or 6mm. What’s right for my 998 cooper brakes?
Edited by Minigman, 17 November 2020 - 12:47 PM.
Posted 17 November 2020 - 12:46 PM
Posted 17 November 2020 - 01:31 PM
Edited by Minigman, 17 November 2020 - 01:38 PM.
Posted 17 November 2020 - 01:58 PM
The original ones. The thin. But I would not bother with them. Like I said they were removed from production.
Posted 17 November 2020 - 02:13 PM
I think my brain finally has this processed now!
Posted 17 November 2020 - 05:17 PM
The Thin ones were fitted for a very short time between the Outer Seal and the Bearing and the Thicker types between the Inner Seal and the Bearing.
After pulling down so many hubs and finding the seals butted up against the Bearings, I make and fit these to all hubs I do.
Red outside, Yellow inside.
