Mpi Brake Servo Issues
1 reply to this topic
#1 toplessmini
toplessmini
  • 499 posts
  • Local Club: none on the island....
Posted 14 November 2020 - 09:52 PM
Before i remove the servo and master cylinder, my question is this. Can the cylinder leak into the servo?
My cylinder is quite new and has had minimal usage. Using an easy bleed system today it seemed that brake fluid was coming from the rear of the servo. Is this likely?
Thanks in advance.
#2 panky
panky
  • 1,853 posts
Posted 14 November 2020 - 11:19 PM
It is certainly possible. I had this very issue a little while ago, a good amount of brake fluid was in the servo that had leaked out of the master cylinder, quite frightening when the brake pedal goes to the floor O_O
2aXSzk2.jpg?1
Edited by panky, 14 November 2020 - 11:22 PM.
