1990 Cooper Fusebox Connections
9 replies to this topic
#1 beardylondon
beardylondon
  • 1,464 posts
Posted 06 November 2020 - 03:50 PM
Hi All
So I have my new fusebox in, which has solved by main issues.
The next job is to replace the crappy connectors, I have sourced the correct PoziLok (AKA Posi Lock) black connectors already, my question is, are the clear ended spade covers OEM too? I have some already, so easy for me to replace like for like, just curious if they are OEM.
Edited by beardylondon, 06 November 2020 - 06:02 PM.
#2 beardylondon
beardylondon
  • 1,464 posts
Posted 07 November 2020 - 04:20 PM
Bump
#3 kit352
kit352
  • 244 posts
Posted 08 November 2020 - 06:42 AM
My 91 has a mix of both as well if it helps. Very annoying really. When i need to replace any i have been using all weather spade terminals.
#4 Bobbins
Bobbins
  • 1,466 posts
Posted 08 November 2020 - 08:16 AM
"all weather spade terminals" ???
#5 kit352
kit352
  • 244 posts
Posted 08 November 2020 - 08:44 AM
They are spade terminal with thick shrink tubing over them. Not the hard plastic ones and they remain soft. They have a bit of glue in them that seals the back end up.
https://www.amazon.c...s/dp/B07KYMNZMX
#6 Guest_minidizzy_*
Guest_minidizzy_*
  • Guests
Posted 09 November 2020 - 12:41 AM
I had a look at my 1990 RSP Cooper today. I am not sure if this is any help.
Top left is clear. Top right has a blue sleeve.
Next down, left and right are black posilok.
Next down - no left connection but right is pozilik.
Bottom two - no connections.
#7 Cooper Mac
Cooper Mac
  • 222 posts
Posted 09 November 2020 - 09:19 AM
My 1991 Cooper has Pozilok Connectors for all terminals on the Fuse box, and most of the other connections too. The only ones I can think of that were the clear plastic ones were the Heater switch....
#8 GraemeC
GraemeC
  • 7,420 posts
Posted 09 November 2020 - 10:56 AM
That's far from standard then - a blue crimp is certainly not OEM and not having a connection to some of the fuses is certainly odd!
#9 panky
panky
  • 1,785 posts
Posted 09 November 2020 - 12:47 PM
Mine as it was originally
#10 Guest_minidizzy_*
Guest_minidizzy_*
  • Guests
Posted 10 November 2020 - 02:08 PM
Your are quite right. I wasn't looking closely enough. There are four pairs of connectors each side of the box. All have posilok connectors except the top two front with the different connectors I mentioned and the another three front ones I also mentioned as having no connectors.
