My mini is a 1994 Mayfair so has a standard 1275 engine.
Edited by Alphaboat, 03 November 2020 - 09:14 AM.
Posted 03 November 2020 - 09:10 AM
Posted 03 November 2020 - 09:14 AM
The balancing cut outs are standard from the factory. As is the cut out to clear the dizzy drive.
Posted 03 November 2020 - 10:50 AM
You'll find that the semi-circular cutting on the webs are to clear the Distributor drive and the more square cut outs were for clamping the crank in the factor to drill the Oil ways - if this is what you are referring to.
The Big End Journal does appear to have some wear in it, it's likely the Crank will need a Grind.
Posted 03 November 2020 - 01:58 PM
Mini Technical Sections →
Problems, Questions and Technical →
Can You Help Me Guys With My Hs4Started by Notwabel , 26 Dec 2024 engine |
Clutch Not DisengagingStarted by Sharks , 15 Dec 2024 engine |
Possible Transmission Problem?Started by aguiloco , 07 Dec 2024 engine |
Crud In Combustion Chamber.Started by Rubbershorts , 16 Nov 2024 engine |
Full Rebuild MethodologyStarted by PeteD , 16 Nov 2024 engine, electrical |
