Random Sizes Oil Pipe Fittings And Banjo Bolt.
engine
Best Answer Moshtaraq , 08 April 2021 - 12:25 PM
Bought a new banjo bolt, drill and tap. Drilled it out, tapped it, problem solved!
Go to the full post
5 replies to this topic
#1 Moshtaraq
Moshtaraq
  • 86 posts
Posted 29 October 2020 - 06:02 PM
Hi again,
I'm in the proces of finishing up my 1330 build and encountered some problems with the banjo bolt. The wrong banjobolt was fitted I think (previous owner just glued it in I guess) Threads seem chewed up in the block. I was looking for the right bolt but can't find it. So I looked at conversion kits, 2 fittings and a braided line. None of the sizes correspond with what I have measured.
The measurements:
  • Banjobolt that came with the engine: Thread minor: 14.7mm, major: 15.6mm
  • Hole in block: 16.2mm
  • Oil filter housing fitting: housing side maj 13mm min 12.3mm
  • Oil filter housing fitting: pipe side maj 15.7mm min 14.8mm
Oil filter housing: 12A2032 So I would think 1/4 pipe thread which is 13.7mm but that's not what I'm measuring?
Banjo bolt should be 11/16unf which is around 17.5mm but I have 5/8 I think? It's a post 1992 engine so it should be 11/16 both block and bolt. The hole in the block is 16.2mm so the threads that are completely gone? Should be around 15mm minor, right?
The more I look into this the less that makes sense.
At this point I'm thinking to buy a conversion kit, drill out the block, tap a bigger thread and buy an extra custom fitting? Or is this saveable with a helicoil?
I'm lost!
Jens
#2 nicklouse
  • 18,583 posts
Posted 29 October 2020 - 06:10 PM
What year is the block? As there are only two thread sizes in the block. Then we can say what it should have been.
ps the measurements will be imperial.
#3 Moshtaraq
Moshtaraq
  • 86 posts
Posted 29 October 2020 - 06:29 PM
It's an A+ 1275 block that's all I know.
WFM 1024 block casting
12g940 head
cam6232 crankshaft
I always thought it was post 1990 but I'm beginning to doubt it because for example the oil filter housing is pre 1992.
I know that everything should be imperial, that's whats driving me crazy.
#4 alanp
alanp
    Starting My Mini Up
  • 3 posts
Posted 30 October 2020 - 05:34 PM
5/8 UNF is the standard size for the banjo bolt hole.
#5 Moshtaraq
Moshtaraq
  • 86 posts
Posted 30 October 2020 - 05:56 PM
exept for after 1992... then it changed to 11/16 unf
#6 Moshtaraq
Moshtaraq
  • 86 posts
Posted 08 April 2021 - 12:25 PM   Best Answer
