1976 Australian Moke.
173 replies to this topic
#121 Martin108
Martin108
  • 148 posts
  • Local Club: Causeway Coast Mini Club
Posted 25 July 2021 - 09:58 AM
A few more bits cleaned up, primed and sprayed.
Attached File  63EC05FF-9B7F-4F37-9E38-AA0371D1C8A1.jpeg   160.83K   0 downloads
#122 Martin108
Martin108
  • 148 posts
Posted 25 July 2021 - 10:03 AM
Started work on the new front hubs. Trying to work out what the white washer and the small metal ring are for?
Attached File  9920156C-ACC0-49D3-861E-CEFFA80A5840.jpeg   48.42K   1 downloadsAttached File  0DF39B00-1EA6-4644-AE57-E473F3986063.jpeg   80.02K   0 downloadsAttached File  A1F63058-336D-4D6C-946F-45DA8032B502.jpeg   64.88K   0 downloadsAttached File  31645E80-97CA-4DD9-94BF-2D486C8B8372.jpeg   31.45K   0 downloads
#123 KTS
KTS
  • 2,423 posts
Posted 25 July 2021 - 12:02 PM
metal ring fits between the inner races to give the correct spacing/preload on the outer races - they're matched to the bearing assemblies, so don't mix them up
the white plastic ring fits to the cv joint shaft and covers the inboard oil seal as added protection
#124 Spider
  • 14,850 posts
Posted 25 July 2021 - 07:51 PM
Nice that the domestics and marriage counseling is out of the way and you can now return to what's important in life,,,,
Looks good there Martin. I can't remember if I have mentioned it elsewhere. I fit Hydrolasic bump stops on the front. These of course, fit the the arms. The standard types work no different to the subframe mounted types, however, the benefit of them is that they are very easy to replace if that ever becomes necessary. I actually run the Competition types, I find these utter magic and quite delightful to run with. Why all bump stops aren't of this design I have no idea. They are also even easier to replace, needing no tools - other than a jack and wheel brace - to replace.
There's a few tips on fitting up the front wheel bearings here (though maybe too late ?);-
https://www.theminif...wheel-bearings/
In your photo 2 up, with the arms and brackets etc, what's the bracket on the right for ? I don't recognise it, though could be a modified fuel tank lower mount ?
#125 Martin108
Martin108
  • 148 posts
Posted 28 July 2021 - 10:06 PM
Chris, not totally out of the way but sufficient to get me back into the garage again.
I’ll look into the bump stops, like everything else so far it’s all a learning curve. The post on the wheel bearings is excellent, a serious bit of precision engineering. I take it nothing is thrown together in your world. I’ll study it carefully.
You are correct, it is a modified fuel tank bracket. I didn’t fancy drilling into the tub which is where the original fixing hole looked like it was going to end up. The additional leg will allow me to drill into the lower part of the body , the same section where the fuel tank cover fixing holes are located. I’m struggling to get the fuel tank neck to be positioned centrally in the opening on top of the body. I’d thought about adding additional brackets to the top of it so it would pull up into position. That’s another item to sort.
#126 Martin108
Martin108
  • 148 posts
Posted 15 January 2022 - 09:22 PM
I’m back in the garage.  Time to get the Moke rolling.
#127 Martin108
Martin108
  • 148 posts
Posted 25 January 2022 - 10:39 PM
It’s been a while since I uploaded any pictures. Struggling a bit.  Has something changed?
#128 Spider
  • 14,850 posts
Posted 26 January 2022 - 07:04 PM
Are you trying to up-load direct to the forum ? If so, the photo size limit is 2 mb. If you use a host, like Imjur, that's no longer an issue. While it's a little 'clumsy' I actually prefer it as I sit on a few forums and it makes posting up photos as well as finding older photos, easier.
#129 Martin108
Martin108
  • 148 posts
Posted 06 March 2022 - 01:00 PM
Picture issue sorted, subscription had expired.
Attached File  A1B654A9-40C1-4FB0-AC83-285642039979.jpeg   47.98K   1 downloadsAttached File  AEF609ED-FD73-43B9-B8D9-ED191C474331.jpeg   35.37K   2 downloadsAttached File  A78D0B82-79BC-4863-912B-575A8D7352BD.jpeg   45.81K   2 downloads
Edited by Martin108, 06 March 2022 - 01:02 PM.
#130 Spider
  • 14,850 posts
Posted 08 March 2022 - 04:54 PM
Beautiful work there Martin.
Is that your workshop bench ?
Nice and clean, just the right sort of environment for putting such an assembly together. It's a real credit to you and to your discipline.
#131 Martin108
Martin108
  • 148 posts
Posted 09 March 2022 - 11:41 PM
Chris, I can’t work with stuff everywhere. Everything has a place.
Attached File  EA50BF1E-BC4F-4FAF-96C5-ED773F11E6FE.jpeg   58.03K   1 downloadsAttached File  FD7A0595-901E-427C-B685-17BECBF7D4DD.jpeg   142.35K   1 downloads
Edited by Martin108, 09 March 2022 - 11:45 PM.
#132 Martin108
Martin108
  • 148 posts
Posted 09 March 2022 - 11:43 PM
Sorting out rear seat fixings.
Attached File  54A260E3-A815-417F-9400-4F4E4BB0A8EF.jpeg   40.64K   0 downloadsAttached File  50039F6B-50BB-4834-A0F6-4E1DF72EA013.jpeg   38.48K   0 downloads
#133 Spider
  • 14,850 posts
Posted 10 March 2022 - 05:33 PM
Seats looking good there mate, got the right bracket (of course).
Have you anything particular in mind for trim style / colour yet ?
When are you free to come sort out my shed ?
#134 Martin108
Martin108
  • 148 posts
Posted 15 March 2022 - 07:02 PM
I want it to look like the green one on the Moke Panels web site.
Attached File  4BF6974C-1F38-493F-B171-F6C41CAF27DE.jpeg   130.85K   0 downloads
#135 Martin108
Martin108
  • 148 posts
Posted 20 March 2022 - 08:53 PM
It’s a nightmare trying to get all the fixing points for the seats to match up with the holes in the bodywork. I think I’m going to have to drill new holes in the seat frames and fill in the old ones.
Attached File  80FE64E6-B948-4A06-A1FB-D97B73B9920B.jpeg   41.9K   0 downloads
