1976 Australian Moke.
173 replies to this topic
#76 Martin108
Martin108
  • 148 posts
  • Local Club: Causeway Coast Mini Club
Posted 24 February 2021 - 10:42 PM
Essential tools for quickly removing an inner race.
Attached File  8E8644F5-25E7-4C0B-BAD1-0ECC6D8E3FF6.jpeg   79.96K   0 downloads
#77 Martin108
Martin108
  • 148 posts
Posted 24 February 2021 - 10:49 PM
Hub in position, retaining washer, castle nut and split pin in place. I banged the grease cap too hard and dented it. I’m replacing it with an alloy one. The Superfin alloy alloy brake drums look good. Can you see the dent?
Attached File  BE4AC299-1BBA-4D28-8400-944034C5BFCC.jpeg   73.54K   0 downloadsAttached File  6934BEC1-BCBC-4A98-A582-48F346E636A1.jpeg   67.24K   0 downloadsAttached File  3967184B-D87E-44EC-8AD6-448C6D26548A.jpeg   58.61K   0 downloads
Edited by Martin108, 24 February 2021 - 10:50 PM.
#78 Martin108
Martin108
  • 148 posts
Posted 24 February 2021 - 10:51 PM
One side ready for assembly.
Attached File  18730AC6-6C56-4D43-9F20-40DAEABD0673.jpeg   76.34K   2 downloads
#79 Spider
  • 14,850 posts
Posted 27 February 2021 - 06:42 PM
I know the frustration of dinged or dented Caps. Just about every one I come across here looks like it's been used for punching practice. They still do their job, but look awful. I usually fit new Steel Caps (my pockets aren't as deep as yours !) I made a tool for fitting them without the risk of damage;-
While I turned the ID here from the Bell End of some 50 mm conduit, there maybe a Plumbing Fitting that's the right size, or, with Conduit, it can be carefully heated with a hot air gun to soften it, then make the Bell a little larger. The Hose Clip possibly isn't necessary, I only fitted it as 'insurance' as I turned this one and the wall thickness is a little thin.
#80 Martin108
Martin108
  • 148 posts
Posted 27 February 2021 - 07:47 PM
A simple engineering solution to a problem. I didn’t realise I could get alloy grease caps, not as expensive as you might think.
Edited by Martin108, 28 February 2021 - 11:00 AM.
#81 Spider
  • 14,850 posts
Posted 27 February 2021 - 08:04 PM
A simple engineering solution to a problem. I didn’t realised I could get alloy grease caps, not as expensive as you might think.
To be honest here, I've never actually gone looking, but you've given me an idea,,,,,, Cheers  :D
#82 Martin108
Martin108
  • 148 posts
Posted 27 February 2021 - 08:20 PM
Attached File  374425D8-6EDE-4F3F-BB92-1AF2179D1376.png   240.08K   4 downloads
Attached File  ABD4E704-DC8A-4EA8-824F-AB73491C414B.png   168.25K   1 downloads
Edited by Martin108, 27 February 2021 - 08:23 PM.
#83 Martin108
Martin108
  • 148 posts
Posted 28 February 2021 - 01:00 PM
When it’s dry in Northern Ireland you just have to set the Moke aside and put a few miles on the Mini. This is Katie my 1992 Mayfair.
Attached File  DAF61AFC-AE99-4B5E-9A45-6FDD432555E3.jpeg   61.34K   0 downloadsAttached File  1074F27C-254C-406B-A85C-1F5B2199D5E4.jpeg   135.52K   0 downloadsAttached File  1BE4902F-9EEF-4014-85AF-5B93190958F2.jpeg   46.95K   0 downloads
#84 Spider
  • 14,850 posts
Posted 28 February 2021 - 05:20 PM
Looks like new !
#85 Martin108
Martin108
  • 148 posts
Posted 28 February 2021 - 07:51 PM
It nearly is. This was my Grandad’s car. He left it to me when he died.
Attached File  990734B5-4AF5-4E49-974A-7312166D302F.jpeg   61.16K   4 downloadsAttached File  30C55984-9B98-46D0-8FFB-EE262BCC6D5A.jpeg   60.73K   1 downloadsAttached File  2021FC77-7267-477C-AA56-44FA087D034C.jpeg   58K   0 downloadsAttached File  A77E35EC-0668-43EB-8AC4-A77460AA9F67.jpeg   50.11K   0 downloadsAttached File  D9E69F45-EEE8-404F-9E1B-68B29885343A.jpeg   47.79K   0 downloadsAttached File  0B3F4146-FCFA-48C6-A96A-43F6D561501A.jpeg   47.68K   0 downloadsAttached File  D7F0EF8F-7C9D-4C43-9CBF-785BF3FB2745.jpeg   51.47K   0 downloadsAttached File  6CBC477C-3248-4EF3-82F2-5E2AB9A310AC.jpeg   54.22K   0 downloadsAttached File  16E72E8B-361F-4399-9761-18AB0EA7748E.jpeg   60.63K   0 downloadsAttached File  10751309-9D69-453E-9323-E4CFBDA34088.jpeg   39.39K   1 downloadsAttached File  0ED8D807-1BFD-426C-BD5B-04C96CD9613D.jpeg   36.73K   2 downloads
Edited by Martin108, 28 February 2021 - 08:06 PM.
#86 Martin108
Martin108
  • 148 posts
Posted 28 February 2021 - 10:31 PM
I started to assemble the rear suspension. The radius arms and the Hi Lo’s went in ok. When I offered up the Spax shock to the radius arm, the end wouldn’t go over the connection. I initially thought I’d got the wrong end on the Spax but after a quick consultation with all the Mokers on the internet I discovered an inner from the old shock absorber was still in place. That would be par for the course with this build, an inner from a bearing in the radius arm, the inner race on the hub shaft and now this. What next? A quick twist with a pair of vice grips and the inner came off, letting me fix the Spax shock in place. Result!!
Attached File  40F44382-471E-4AD6-B9AE-169D4F845604.jpeg   115.94K   0 downloads
Attached File  87E4CF3B-6763-47A5-A061-93DFAFA69FE3.jpeg   101.35K   1 downloadsAttached File  3D3A8BA2-3936-4861-AAF7-232CD51F9AE7.jpeg   94.46K   1 downloadsAttached File  EE628172-B881-4DA6-9EC7-A93115196057.jpeg   99.83K   1 downloads
#87 Martin108
Martin108
  • 148 posts
Posted 28 February 2021 - 10:34 PM
When fitting the rubbers I notice some dots painted on the underside. They all had three green dots but two had a white dot and two had a pink dot. Are all the rubbers the same?
Attached File  8A8138EF-13C1-464B-A18A-437960B933EB.jpeg   168.89K   0 downloads
#88 Martin108
Martin108
  • 148 posts
Posted 28 February 2021 - 10:38 PM
I’ve been wanting to put these wheels on for ages. I’m very pleased with the results.
Attached File  F535435C-6BBD-41D2-A2C0-62D281E69985.jpeg   114.54K   4 downloads
#89 Spider
  • 14,850 posts
Posted 01 March 2021 - 08:19 AM
Martin, your Grandad's Mini came up amazing, especially considering where you started from with it. Extra credits for that one! I can't believe it's the same car !
The sleeve 'trick' is fairly common, yours came off easy, some need filing off. The Stud is easy to remove to make the job easier if it wants to put up a fight.
In regards to the coloured dots on the M-parts Cones, I've noticed them too, however, when I've tested them, there's no difference between them. Only a guess but I suspect it's some type of QC or dating code.
#90 Martin108
Martin108
  • 148 posts
Posted 13 March 2021 - 08:42 AM
More progress, I’ve got two wheels on my wagon.
Attached File  01991C54-CBCA-47A3-83E0-E29238DC0EA8.jpeg   46.57K   1 downloadsAttached File  F04516CD-2ACA-430C-BB28-3145CD29D998.jpeg   53.4K   0 downloadsAttached File  1187D541-2B41-47D4-97FE-A556311C5ABE.jpeg   59.11K   0 downloads
