1976 Australian Moke.
173 replies to this topic
#61 KTS
KTS
  • 2,459 posts
Posted 23 January 2021 - 10:08 AM
could you modify the frames to fit the brackets ?
#62 Martin108
Martin108
  • 148 posts
  • Local Club: Causeway Coast Mini Club
Posted 23 January 2021 - 07:27 PM
No I looked at that. I ordered a spot weld drill bit today, let’s see what next week brings.
Edited by Martin108, 23 January 2021 - 07:27 PM.
#63 Martin108
Martin108
  • 148 posts
Posted 27 January 2021 - 10:33 PM
So I bit the bullet today, one side done. Mixed emotions as the lads who did the body work made such a good job.
Attached File  6E07901D-2444-42AE-9ACD-FC0A1A600020.jpeg   31.12K   0 downloadsAttached File  05C25E5C-4F3E-4437-9292-15FCD3753298.jpeg   37.28K   1 downloadsAttached File  27FD3BCA-98A7-4C4D-8CC5-E8CFED156515.jpeg   59.08K   2 downloads
#64 Spider
  • 15,106 posts
Posted 28 January 2021 - 06:21 PM
Taken the plunge !
If one is careful in removing these parts - as you have been - then if you change your mind, it should all be reversible, though I'm somewhat sure you won't here.
#65 Martin108
Martin108
  • 148 posts
Posted 28 January 2021 - 10:49 PM
Taken the plunge !
There was nothing careful about the removal. They were spot welded, welded and fixed with a bonding adhesive.
#66 Martin108
Martin108
  • 148 posts
Posted 18 February 2021 - 08:50 PM
I’ve been looking at my handy work for the past week or so. I’m regretting it a bit. I think I might be going back to the Perspex frames.
Attached File  C89950F7-E1A7-4945-A551-9A82CC2D2F71.jpeg   42.55K   0 downloadsAttached File  BE464CFC-5A40-435B-A7CA-5DBBF358C7A5.jpeg   57.72K   0 downloads
#67 Martin108
Martin108
  • 148 posts
Posted 18 February 2021 - 09:12 PM
My Moke came with an 850cc engine. I believe it originally had an 1100cc engine. I picked this one up from Mervyn Johnston who’s well known in Mini circles in Northern Ireland. He’s left it ready to add a carb, a coat of paint (colour to be decided) and pop it in. He has some nice cars in his garage.
Attached File  57E9F287-BF3C-419E-A9D5-F7D1CBB2CFD0.jpeg   61.87K   3 downloadsAttached File  7537FF5C-017E-488B-A4CD-09AC6E532FE9.jpeg   60.38K   2 downloads
Edited by Martin108, 18 February 2021 - 10:06 PM.
#68 Spider
  • 15,106 posts
Posted 19 February 2021 - 07:11 PM
I'm sorry you're disappointed here, what don't you like about your work or the frames ?
Actually, during 1975, they ran out of stocks of locally assembled 1100 engines (with the closure of Zetland the previous year) and begun fitting fully imported 998's. These were painted Black, top to bottom.  All the same, if you have tee'd up an 1100, I'd suggest running with that.
#69 Martin108
Martin108
  • 148 posts
Posted 19 February 2021 - 07:46 PM
I’ve been looking at the bare metal thinking I really bodged it. Perhaps I will prime it and it will look better. I also like the view through the Perspex with no metal frame.
You sir are a font of all knowledge. You know I want a green one. I’ve actually managed to tee up two 1100 engines.
Edited by Martin108, 19 February 2021 - 07:50 PM.
#70 Martin108
Martin108
  • 148 posts
Posted 21 February 2021 - 12:05 AM
Working on the radius arms. When I stripped out the old bearing I managed to damage it and didn’t realised the outer sleeve was still in the radius arm. When I inserted the new bearings and metal tube I managed to compress the metal tube. It took me three hours with a file and hacksaw blade to get the tube out. I had to get two new tubes machined locally. It all looks well now and the radius arms are getting there.
Attached File  9ADD3B38-D00B-4FF6-A4AE-C7C4DA25CEFF.jpeg   39.79K   0 downloadsAttached File  B1F729A6-E495-4E90-90EC-BC5FF7434189.jpeg   56.92K   1 downloadsAttached File  05FA8409-4D34-474A-9ECC-4000A53DDA43.jpeg   73.26K   0 downloadsAttached File  AF1CEB10-7B79-4A91-BBCF-82B93C366A2B.jpeg   67.61K   0 downloadsAttached File  02A18384-0B0B-4711-9E0E-E6999380CFF3.jpeg   70.52K   0 downloads
#71 Spider
  • 15,106 posts
Posted 21 February 2021 - 08:15 AM
Nice fix !
Martin, that assembled Arm looks so nice !   Shame they don't stay that way >_<
#72 Martin108
Martin108
  • 148 posts
Posted 21 February 2021 - 05:21 PM
Nice fix !
I look forward to getting it dirty.
#73 Martin108
Martin108
  • 148 posts
Posted 22 February 2021 - 10:11 PM
New bearings going into the hubs.
Attached File  DEA8A101-87FB-4CA6-A65B-7D0F1B35F03D.jpeg   77.02K   0 downloads
#74 Martin108
Martin108
  • 148 posts
Posted 23 February 2021 - 11:01 PM
So tonight I found out what an inner race is. Tried to put the hub with the new bearings onto the radius arm and couldn’t figure out why it wouldn’t go right down. The inner race from the old bearing was still on the shaft. A wee bit heat from a turbo torch then my trusty hammer and a small chisel sorted the problem.
Attached File  E6B4DD0C-36D0-49D4-B0CD-8E394778F422.jpeg   71.04K   0 downloadsAttached File  D1F9E373-1000-4F56-98C4-48A676BF1896.jpeg   144.92K   0 downloads
#75 Spider
  • 15,106 posts
Posted 24 February 2021 - 04:53 AM
Good work mate. I'm glad you went about it in that way. I've seen a few who have tried it with an angle grinder and damaged the arm !. The Boss just behind the inner race is important as that's were the seal runs, and it's also part of the arm !
