Rear Wheel Bearings
22 replies to this topic
#1 DUF2
DUF2
    Formally known as DUFfi
  • 469 posts
  • Local Club: Whickham & DMC
Posted 22 October 2020 - 07:06 PM
My ‘65 Elf has dry suspension and the rear wheel bearings are ball races, one of which has a bit of play in it
i see later Minis have taper roller bearings. Would I need new hubs if I was to fit taper roller bearings?
or can I simply replace the worn ball race with a taper roller bearing?
#2 cal844
cal844
  • 9,735 posts
  • Local Club: TFMOC
Posted 22 October 2020 - 07:53 PM
Taper roller bearings should fit as they are dimensionally identical Iirc, someone will confirm either way.
#3 nicklouse
  • 19,066 posts
Posted 22 October 2020 - 08:11 PM
As above but only use Timken ones. But I would keep on the ball bearings.
#4 cal844
cal844
  • 9,735 posts
  • Local Club: TFMOC
Posted 22 October 2020 - 08:24 PM
I agree, keep the car as close as possible to original specifications
#5 Tornado99
Tornado99
  • 750 posts
Posted 23 October 2020 - 09:46 PM
I attempted to swap ball for taper bearing last week. But had to give up once I found the inner, inside bearing race stuck to the spindle. I know these can be removed with angle grinding but I was not in a position to perform that, as I have to work in a parking spot of my condo underground parkade.
I will have to take it to shop.
#6 Dusky
Dusky
  • 5,322 posts
Posted 24 October 2020 - 07:55 AM
Or SKF, FAG,... basically any reputable bearing maker.
#7 cal844
cal844
  • 9,735 posts
  • Local Club: TFMOC
Posted 24 October 2020 - 09:35 AM
I bought an SKF boxed front bearing that was a Timken bearing, I was surprised to say the least
#8 DUF2
DUF2
  • 469 posts
Posted 24 October 2020 - 10:49 AM
What grease should I use for the bearing? I have a pot of LM grease.
thanks for all your comments. I will use Taper roller bearings as my car is no longer standard 1275 A+ engine, 8.4 vented discs & callipers. So the change from ball to taper roller bearings will not affect the value of the car.
#9 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,189 posts
  • Name: Neil
Posted 24 October 2020 - 11:53 AM
A lot of the time, replacement wheel bearings come with a packet / tube of grease. Tip, do not use bare hands when applying grease to the bearing. Always use Nitrile gloves.
This is more down to prevent the moisture off your hands damaging the bearing before you apply grease.
LM grease should be fine though.
#10 Dusky
Dusky
  • 5,322 posts
Posted 24 October 2020 - 04:39 PM
Would instantly ask a replacement from my supplier..
#11 sonikk4
sonikk4
  • 16,189 posts
  • Name: Neil
Posted 24 October 2020 - 05:33 PM
Why when Timken is one of the best ones out there.
#12 Dusky
Dusky
  • 5,322 posts
Posted 24 October 2020 - 08:43 PM
Because you bought an SKF. A supplier that puts one brand bearings in another brands boxes cannot be trusted. Always use a supplier you can trust too many counterfeit bearings out there.
#13 sonikk4
sonikk4
  • 16,189 posts
  • Name: Neil
Posted 24 October 2020 - 09:31 PM
What tickles me here and not arguing against incorrectly boxed bearings, is that SKF although Swedish, they now are consolidating three sites all in China. So here we are on a forum that has so many issues with so called Chinese copy cat items, whether its bearings or whatever, and a major player in the production of high end bearings now operates in China!!!!
And then Timken which has been taken over by Koyo which has operations in North America, Europe and then last but not least CHINA. Go figure!!!!
Everyday is a school day.
#14 mini-mad-mark
mini-mad-mark
  • 926 posts
  • Local Club: northants wot no brakes
Posted 24 October 2020 - 10:04 PM
Timken has NOT been taken over by Koyo......
#15 Dusky
Dusky
  • 5,322 posts
Posted 24 October 2020 - 10:23 PM
So? As you said, there is a difference between copycat bearings and genuine bearings.
The place of manufacturing has nill to do with the quality of the bearing and everything with the standards to which a product is produced and what quality control there is. Where do you think all of the high quality powertools like milwaukee and the likes are made? Totally irrelevant to my original point too anyway.
