Sticking Clutch
17 replies to this topic
#16 DUF2
DUF2
    Formally known as DUFfi
  • 456 posts
  • Local Club: Whickham & DMC
Posted 18 December 2020 - 12:45 PM
Just to conclude this topic.
I now have the new spring fitted as advised by GraemeC, this spring is a lot lighter as a result it is much easier to check clutch adjustment free play.
many thanks for all your support with this
Here is the new spring in situ
Attached File  4B02CD25-D6C8-4773-ABDE-0062B9488DC6.jpeg   84.57K   0 downloads
#17 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 18 December 2020 - 02:15 PM
What was the fault? Asking for future reference
Basically adjustment.
I have never driven the car so did not know how the clutch should feel. The new return spring is quite heavy, When I was pushing the pedal I thought it was disengaging the clutch, but all I was doing was stretching the spring. In addition the hydraulics were full of air.
Once bled & adjusted the clutch now disengages, albeit a bit heavier than I thought it should be.
Rather embarrassing.
Dont feel embarrassed, you didn't know the answer to the fault so had to ask. Answering a question that you don't know the answer to is why forums are still in existence 😊
Please don't hesitate to ask about anything you query
#18 DUF2
DUF2
  • 456 posts
Posted 18 December 2020 - 04:47 PM
I find these forums very good. If you have a problem, ask, someone else has probably had the same problem and has a resolution to the issue.
