Sticking Clutch
17 replies to this topic
#1 DUF2
DUF2
    Formally known as DUFfi
  • 456 posts
  • Local Club: Whickham & DMC
Posted 19 October 2020 - 01:14 PM
My Elf is undergoing a l o n g rebuild, just me being lazy!
The clutch was replaced 3 years ago but the car has not been out on the road, it is still on axle stands.
The pedal feels fine and all seems in order, but I then thought, I bet the pressure plate is stuck.
So I fired up the engine, but with the clutch pedal down the clutch must not be disengaging as I cannot get it into gear.
Engine off gear selection is no problem, but engine running it won’t go into a gear, started it up in 4th gear, clutch pedal down the. put the brakes on and the engine stalls which makes me think the clutch plates are stuck together.
has anyone any bright ideas on how to free the clutch?
#2 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 19 October 2020 - 01:19 PM
What you need to do is put the car on the ground then start it in gear... Make sure you have plenty room around the car.
If that doesn't work try using the handbrake once the car starts to move.
#3 GraemeC
GraemeC
  • 7,438 posts
Posted 19 October 2020 - 01:25 PM
First make absolutely sure the clutch arm is moving properly when you press the pedal - the push rod should move out of the slave cylinder by approx 0.5"
If that's all good, then as Cal says - you need to try and shock it free. It will go suddenly!
If that fails, then its flywheel disassembly time!  Depending on what is stuck to what, you may be able to free it by removing the diaphragm and not having to pull the flywheel.
#4 Spider
  • 14,842 posts
Posted 19 October 2020 - 05:46 PM
If Cal and Graeme's suggestions don't work, you can sometimes remove the Starter Motor, jam the Clutch arm out as far as it will go, then get a lever in through the Starter hole to separate the Back and Clutch Plate.
#5 DUF2
DUF2
  • 456 posts
Posted 22 October 2020 - 09:18 PM
I am thinking of how to shock this free.
i intend the wedge the clutch arm in the open position then run the engine in gear then stamp on the brakes. But which gear should I use? Top gear or bottom gear?.  I cannot get it into my head which way would be best.
#6 GraemeC
GraemeC
  • 7,438 posts
Posted 22 October 2020 - 09:36 PM
Top
(think which gear you’d expect a clutch to first start to show signs of slipping)
Edited by GraemeC, 22 October 2020 - 09:37 PM.
#7 DUF2
DUF2
  • 456 posts
Posted 20 November 2020 - 06:16 PM
I have been unable to try out freeing the clutch until today. I wedged the clutch release arm fully open
3000 RPM in top gear, stamp on the brakes and the engine immediately stalls.
tried a couple of time using both bottom & top gear but the clutch STILL will not disengage!!!
I renewed the clutch around this time in 2017, but the car has not been on the road, so am not sure if the friction plate is just stuck or if I could have done something wrong when I replaced the clutch!
Any ideas on how to resolve this would be gratefully appreciated.
Edited by DUF2, 20 November 2020 - 06:21 PM.
#8 GraemeC
GraemeC
  • 7,438 posts
Posted 20 November 2020 - 07:56 PM
I’d whip the wok off and take a look.
(actually I’d pull the flywheel)
#9 bpirie1000
bpirie1000
  • Area Managers
  • 2,344 posts
  • Local Club: Amoc
Posted 24 November 2020 - 05:51 PM
Is the clutch in the right way round?
#10 DUF2
DUF2
  • 456 posts
Posted 25 November 2020 - 05:28 PM
I did wonder about this, but GraemeC suggested this is not possible to do.
I have re assembled the car but have not yet fired it up. I suspect I have resolved the issue.
#11 MiniMadRacer
MiniMadRacer
  • 889 posts
Posted 25 November 2020 - 08:35 PM
Make sure the clutch arm ball has not cracked or snapped off. I have unstuck clutches the way you are doing it.... car on axle stands at the front,  hand brake on, rear wheels chocked, no one and no objects in front of the car, get the wheel spinng up to about 30 mph and depress the clutch fully and stamp on the brakes...after 3 or 4 attempts this has always worked for me.... only other thing I have done is make sure the car is fully warm.... a bit of heat transfering to the flywheel and clutch can help unstick it so make sure everyhting is up to temp before trying it...
#12 DUF2
DUF2
  • 456 posts
Posted 27 November 2020 - 03:25 PM
Issue resolved!!
I’m a bit embarrassed at the problem!!
thanks to all who offered advice.
Edited by DUF2, 27 November 2020 - 04:00 PM.
#13 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 27 November 2020 - 05:04 PM
What was the fault? Asking for future reference
#14 DUF2
DUF2
  • 456 posts
Posted 27 November 2020 - 10:08 PM
Basically  adjustment.
I have never driven the car so did not know how the clutch should feel. The new return spring is quite heavy, When I was pushing the pedal I thought it was disengaging the clutch, but all I was doing was stretching the spring. In addition the hydraulics were full of air.
Once bled & adjusted the clutch now disengages, albeit a bit heavier than I thought it should be.
Rather embarrassing.
#15 Quinlan minor
Quinlan minor
  • 1,171 posts
  • Local Club: LSMOC
Posted 27 November 2020 - 11:53 PM
To quote one of my daughter’s Primary School teachers:
“Mistakes are good. You learn from them”
Glad you are up and running now.
