Posted 07 November 2020 - 04:00 PM
Posted 07 November 2020 - 05:09 PM
Posted 07 November 2020 - 05:58 PM
Where was the number plate from?
Posted 07 November 2020 - 07:10 PM
really enjoying this build, especially enjoying seeing the bare shell inside with all your routing of wires etc. really great
Posted 08 November 2020 - 07:58 AM
Thanks,
Maccmike8 the number plate was printed by a company called Crispy designs.
Edited by fiestaharry, 08 November 2020 - 07:59 AM.
Posted 10 November 2020 - 05:27 PM
Posted 15 November 2020 - 03:08 PM
s3swiss, rear subframe fit great, although i used a genuine subframe for mockup all the way through the build to keep checking it.
The car seems to have an equal amount of toe in at the rear which may need a spacer on each from minispares. Which i heard is very common on the repro frames.
Posted 15 November 2020 - 03:56 PM
Posted 15 November 2020 - 05:31 PM
Very very attractive.
Posted 15 November 2020 - 08:03 PM
Posted 15 November 2020 - 10:33 PM
Posted 29 November 2020 - 12:41 PM
Not a have amount of progress gone on, but my protech shock arrived along with some other bits:
Got both seats in and fully bolted down, just waiting for the TRS 3 point harness now to arrive to finish them off:
And got the fuel tank bolted in, and squeezed my lp883 with 165 tyre in, which will probably have to make an offset ring made to bolt it down as it doesnt tuck under the tank.
Posted 12 December 2020 - 09:46 AM
Posted 01 January 2021 - 04:42 PM
Edited by fiestaharry, 01 January 2021 - 04:43 PM.
Posted 08 January 2021 - 08:03 PM
Over the past few days been messing with some bits:
Wired up the dash and got it fitted, along with my Sabelt wheel ( which im really happy with!):
Got some split collars and tig welded a rod on there to keep the harnesses in place:
When my minispares order came in, i had some alloy pedal covers in there, after bolting them on, wasn't overly happy with the look and fixing capability on there, so just went with a simple mild steel cover and tig welded them onto the original pedal:
Got the throttle pedal extension bolted on also, after some modifications (the tig really comes into its own on the final stages of the build)
Engine bay is in chaos at the moment, due to waiting on a few bits:
Got some spraying to do tomorrow, got the pedals to spray again, and alot of brand new parts from suppliers where the paint quality is shocking to redo!!!
Edited by fiestaharry, 08 January 2021 - 08:03 PM.
