Gearbox Help Please
21 replies to this topic
#1 richw911
richw911
  • 2,084 posts
Posted 17 October 2020 - 12:42 PM
5Y8iAcs.jpgAfternoon guys. A friends mini was jumping out of second gear, we have separated the gearbox and found this piece in the bottom of the gearbox, whst is it?
It was only jumping out of second gear - no other gears
Edited by richw911, 17 October 2020 - 07:08 PM.
#2 gazza82
gazza82
  • 3,012 posts
  • Local Club: TMF+
Posted 17 October 2020 - 12:55 PM
Was there meant to be a picture?
#3 Maccmike8
Maccmike8
  • 1,101 posts
I cannot see a picture.
#4 bpirie1000
bpirie1000
  • Area Managers
  • 2,343 posts
  • Local Club: Amoc
Posted 17 October 2020 - 01:06 PM
From the picture these look like copper..
Is that correct? Selector fork possibly.
What are the symptoms of the fault?
Edited by bpirie1000, 17 October 2020 - 01:42 PM.
#5 richw911
richw911
  • 2,084 posts
Posted 17 October 2020 - 01:37 PM
Sorry guys not sure what happened photo now added !
#6 richw911
richw911
  • 2,084 posts
Posted 17 October 2020 - 01:44 PM
its not copper no. the fault is it jumps out of second gear ONLY - no other gears.......
Edited by richw911, 17 October 2020 - 01:44 PM.
#7 Ethel
  • 25,919 posts
Posted 17 October 2020 - 03:23 PM
Something for scale would help. Diff shim? Primary gear thrust washer?
Nothing that'd be related to 2nd gear  :-|
#8 bpirie1000
bpirie1000
  • Area Managers
  • 2,343 posts
  • Local Club: Amoc
Posted 17 October 2020 - 04:38 PM
Did that come out the sump plug? Or is it bigger..
Is the box off the block?
#9 Spider
  • 14,841 posts
Posted 17 October 2020 - 06:17 PM
Oh dear,,,,
That looks like part of the Mainshaft, it's machined with a spacer / separator that goes between 2nd and 3rd Gears, and it's broken off.
It's the thin part of the shaft that stands well proud of it. This would also be why it jumps out of 2nd.
#10 richw911
richw911
  • 2,084 posts
Posted 17 October 2020 - 07:09 PM
We separated the gearbox it was sat in the bottom
#11 richw911
richw911
  • 2,084 posts
Posted 17 October 2020 - 07:17 PM
Thanks for the input guys
#12 richw911
richw911
  • 2,084 posts
Posted 18 October 2020 - 02:56 PM
new photo,  main shaft im thinking as Moke spider said
#13 Spider
  • 14,841 posts
Posted 18 October 2020 - 07:21 PM
If you look between 2nd and 3rd Gears, you would normally see it.
The Laygear's been removed in this photo, but I'm sure you'll be able to work out where to look from it
#14 richw911
richw911
  • 2,084 posts
Posted 18 October 2020 - 09:01 PM
Moke spider thank you very much
#15 mini13
mini13
  • 3,810 posts
Posted 19 October 2020 - 12:10 PM
yu might be able to see that area down the dizzy hole with a torch.
