Posted 13 October 2020 - 07:18 PM
Posted 13 October 2020 - 09:08 PM
There is a proper strip down and there is a Proper Strip down. Without photographic proof of what has been done then its all down to here-say. And unfortunately you see a lot of that.
Sandblasting or media blasting is good but and its a big BUT, a mini is comprised of 0.9mm and in some places 1.2mm thick steel. So any rust that has been removed by this process and no panel / steel replacement means the material could be a lot thinner than standard.
If everything has been removed / replaced properly, all seams have at a minimum weld through primer in them, sealed properly, cavities painted and waxoyled or similar. and a good quality primer / topcoat then there is nothing to say with decent care and cleaning a restored car can last 10 years plus.
Posted 14 October 2020 - 11:47 AM
Interesting, thanks for the advice Neil.
I will inspect carefully!
Posted 14 October 2020 - 03:09 PM
Also depends what you are using the car for and where. As a shuttle vehicle in the road salt depot it will obviously last less long than as an occasional summer weekend ride -
whatever the previous restorion was like
Mini Technical Sections →
Bodywork, Paint and Detailing →
Wheel Arch Repair For MotStarted by adman020 , 21 Jun 2024 rust repair |
Non- Genuine Door HingesStarted by CBJ805T , 09 Jun 2024 rust repair |
paint
2K Or Not 2KStarted by BobbyMax , 28 Apr 2024 paint |
Where To Start - Rear EndStarted by OzKopite , 03 Mar 2024 rust repair |
Mini Specialist For Welding -South East/south WestStarted by s2ulk , 20 Oct 2023 rust repair |
