English is not my native tongue and I so bear with me:
As I don't know what you have in front of you, I'll do my "I assume nothing" approach combined with my terrible drawing skills:
The items and function:
The bonnet prob (BKD360030) is the bar that hinges from the bonnet and that is secured at the hinge point with a clip (4B8769 - Clevis pin for bonnet safety catch hook). It can be cllipped onto the bonnet via a clip (CZH209 Clip for retaining/parking bonnet prop) when closing the bonnet
The outer end of the prob slides into a slot on a bracket at the innerwing: (14A7806 Bonnet prop bracket) As the end is in an S-shape (or should be) it can not fall through the slot of the Bonnet prop bracket:
Insert the bonnet prop in the the slot at position A and slide it to position B. the shoulder on the bonnet prop will rest on B now. It should not slide towars A on its own.
If the shoulder is not horizontal you shouyld rebend it in a vice (taking of the bonnet prop from the bonnet first)
Does the above help or can you determine what problem you now have?
Regards,
Johnmar
4B8769
