Vanman's Van
18 replies to this topic
#1 Vanman20
Vanman20
  • 274 posts
Posted 05 October 2020 - 04:49 PM
Here's my recently purchased Mini van.
Built in 1982 and restored a few years ago by the previous owner and fitted with a few upgrades including an MG Metro engine + gearbox,8.4" disc brakes and 12" Supalight wheels
#2 Vanman20
Vanman20
  • 274 posts
Posted 05 October 2020 - 04:50 PM
I intend to make various changes and what I consider improvements, as time goes by
#3 unburntfuelinthemorning
  • 1,971 posts
Posted 09 October 2020 - 09:32 PM
What's the interior like?
#4 Vanman20
Vanman20
  • 274 posts
Posted 10 October 2020 - 12:54 PM
I'll be taking it into work next week to overhaul the brakes.....failed mot.....so I'll take some pictures.Emissions were running at 9% too!Supposed to have been rolling road tuned,maybe someone altered it afterwards.Down to 2.5% now and running smoother.
Managed to source some mirrors, I can now see to reverse :)
Also had to replace the ignition barrel,key kept getting stuck in.
#5 Vanman20
Vanman20
  • 274 posts
Posted 10 October 2020 - 01:06 PM
New mirrors
#6 Vanman20
Vanman20
  • 274 posts
Posted 16 October 2020 - 05:34 PM
Fitted quick release bonnet hinges today and got the bonnet gaps better
#7 schelle63
schelle63
  • 29 posts
Posted 20 November 2020 - 09:52 AM
Hi Vanman.
I like thes mirrors! Where are they from?
Markus
#8 Vanman20
Vanman20
  • 274 posts
Posted 20 November 2020 - 11:21 AM
Hi Vanman.
Markus
From here
https://www.classic-...alog/index.html
#9 schelle63
schelle63
  • 29 posts
Posted 20 November 2020 - 07:00 PM
Thank You!
Markus
#10 Vanman20
Vanman20
  • 274 posts
Posted 19 December 2020 - 11:07 AM
Hadn't driven the van for about 2 months so I thought a quick spin was in order.Started 1st time and completed the 10 mile journey.....the longest so far lol.... without any hiccups.
Hope to get some time on it in the new year,got some additional clocks to fit,a new steering wheel and some other jobs I want to do but for now it's back in the garage ☺️
#11 Vanman20
Vanman20
  • 274 posts
Posted 02 March 2021 - 04:14 PM
Done a couple of job this week.
Fitted new door hinges.....went the new pin route at first but that didn't take out all the slack plus some of the threads were damaged so splashed out.
Also removed the towbar....it's for sale for £60 if anyone is interested.Collection from Stoke on Trent
As a result it needed some new number plate brackets so knocked these up
Also lengthened the engine stabiliser bar so the carb doesn't foul the bulkhead any more
#12 Vanman20
Vanman20
  • 274 posts
Posted 05 March 2021 - 04:04 PM
For some reason there's no bracket on the inner wing for the bonnet stay to go in,so I made one.
Replaced the steering wheel from the Mini Ritz one that came with the van.....it's for sale if it's any good to anyone.....to a slightly smaller 4 spoke wheel.Gives a little more leg room so I can fit a dropped bracket next.I'll give it a fresh coat of paint some time in the future
#13 steeley
steeley
  • Just Joined
  • 623 posts
Posted 05 March 2021 - 04:21 PM
Don’t forget to adjust rack if you fit a dropped bracket
I fitted this type to mine
https://www.ebay.co....4.m46890.l49292
Looks very nice and a lot stronger than the std ones
It wasn’t that exact one, mine was about £25
Edited by steeley, 05 March 2021 - 04:27 PM.
#14 Vanman20
Vanman20
  • 274 posts
Posted 24 March 2021 - 04:55 PM
Been working on the cooling system,replaced all the hoses...they were a mish mash of 1/2 inch and 5/8ths...plumbed in the inlet manifold and fitted a solenoid operated valve off a Fiesta to control the heat output from the heater.The heater had a slight leak on it,I couldn't see anything untoward so I just ran some silicon around the plastic flange of the pipes.Unfortunately it's still leaking so a new matrix is on order
Screenshot-2021-03-24-16-43-59-481-com-s
Screenshot-2021-03-24-16-36-12-406-com-s
Screenshot-2021-03-24-16-36-24-807-com-s
I also need a new top bracket for the radiator to thermostat housing if someone can point me in the right direction,seem to be a few options
Edited by Vanman20, 24 March 2021 - 06:14 PM.
#15 Vanman20
Vanman20
  • 274 posts
Posted 24 March 2021 - 05:01 PM
One thing I didn't like was the noise coming from the air filter through the dash.
So I made a panel
As it's not structural I just tack welded it and then ran some pu sealer around the joint and then covered it in 6mm closed foam on both sides
I welded 2 brackets on the inside so the speedo would bolt directly to it
and the fascia just screws on as before
