Hi,
I'm in the process of restoring/rebuilding Mindy, our '93 Mini Tahiti 1.3i (SPI).
This mini was bought new by Brenda in 1993 after having flipped over her new Mini Tropic (that car was written off and was bought back by the Rover dealer that made a cabrio out of it and sold it on).
In 1997 we got married in 1997 and our wedding car was the Mindy mini. We made a trailer out of a mini back end and had went to IMM in Ireland in 1997 with "Mork and Mindy". Life was good. I bought an mini Estate in the UK with plans to restore it, fit a 1.3i in it, but space was an issue..
I've stayed busy in the mini scene in The Netherlands until 2001 when a house move (with a garage) and live took over (starting for my own in 2006 didn't help either on the mini front) . Other cars came as our driving vehicles (among a 1980 mini van with MG Metro engine running on LPG, and a metro on LPG), but at some stage I was fed up working on a mini or metro every weekend in order to get to my work on Monday.. But Mindy was never sold and Brenda drive her until occasionally until 2012. Then she (Mindy, de mini) was parked in the garden behind the house (A bad decision as the hedge she was parked next to prevented wind and in now appears she started to rust fast and blisters appeared on the front wings and all other rust prone areas suddenly became visible). Sadly mini's don't seem made to last, so the tin worm has set in.
Last year I decided to restore/rebuild Mindy, a mini with no previous welding on it what so ever.
Sadly health did not allow me to continue with the plan but I'm getting better (energy wise) and I'm getting back at it, doing things when my body allows and my mind is on it. So this will not be a fast progressing project.
My plans for this car where/are:
Shell:
1) Full strip down
2) Replace al obviuos rusted areas (either new panels or patches is a new panel is overkill)
3) Fit New nose
4) Sandblast and Epoxy prime the shell
5) Repair any new found rusted area's (and epoxy prime them)
6) Refit everything to the shell (engine, wiring, body part) to check if alterations are needed prior to painting
7) tear down everything
Paint
9) Prepare for paint
10) Send off body for paint: Underside, engine bay, sills, inside, bootfloor
11) Bolt subframes back on the shell
12) Build up mini (engine, wiring loom) essentially everything except the interior trim, seats, doors and glass)
13) Send off body for paint: Paint the outside
Engine (that was running fine):
14) De-rust the block and paint it (DONE)
15) replace all seals and bolt on stuff (like water pump etc) (DONE)
16) cleanup all the aluminium (like clutch housing, gear box, diff housing etc) to original state (DONE)
17) Bolting everything back to the engine (DONE)
Currently I'm at 2: replacing/reconstructing the rusted areas.
Possible/planned "modifications":
M1) Fitting a hand operated folding roof (like the webasto from the britisch open, but in this case from a Twingo_. Sliding roof = bought
M2) Fitting a '95 wiring loom with in cabin fuses (and relocating all relays from the engine compartment to the cabin). Wiring loom = bought
M3) Fitting Innocenti quarter lights in the doors, Getting two sets of doors: one orginal, and one with the quarter lights. Innocenti doors/quarter lights = bought
M4) Strengthening the sills: ditching the sling brackets, welding a square bar from front to back to tjhe innersill (being covered by the doorstep and outer sill)
M5) Remove the rear parcel shelve and make the back seat fold able (like in a mini traveller)
M6) Back panel conversion, allowing for
A: one hatchback door,
B: two opening doors (like de auto BMC conversion),
C: a split hatch back top with lower boot lit in original function
M7) M6 may lead to a modified fuel tank (where the spare wheel is), a relocated battery (to the side companion bin), a relocated windowasher bottle (to the side companion bin
Although these modifications are a step from the original, I want to keep the appearance of the car as original as possible, maintaining the Mini Tahiti interior trim (and special seat and door card fabric), keeping the saloon silhouette as closely as possible. Furthermore I want to try to keeping things reversable to the original if possible.
For this project report, I'll backtrack and will post progress and photo's below this project start item.
Johnmar
Edited by Johnmar, 03 October 2020 - 05:44 PM.
