Hi all,
I'm in the process of restoring our '93 mini Tahiti 1.3i (SPI) that we have own from new. (see: http://www.theminifo...ti-restoration/ for the project topic). Everything is stripped down and the body is hanging in a rotisserie.
As the original loom ('93) has seen beter days, I want to replace it with a '95-'96 loom utilizing the advantage of having the fuzebox in the cabin, ditching all those dreaded in line fuses. I had obtained a '95-'96 loom about 20 years ago at a show in the UK. Looking at it now, it appears to have the ECU, relais box and even the immobilizer / alarm, but it misses the keyfobs.
As our '93 never had an immobilizer it was factory fitted with the MNE101040 standaard non cooper ECU. Many years ago this ECU was exchanged by me by a MNE101070 uncoded Cooper ECU. (so I swapped a "sprite" ECU for a cooper ECU). Worked like a charm. As these ECU's are uncoded I never thought of the keyfobs (or the immobilizer itself). I did some reading this week and on cars with an factory immobilizer, the immobilizer code is programmed into the ECU, thereby pairing up the ECU and immobilizer: without the immobilizer code the ECU will not (fully) work: the immobilizer cuts of the power to the fuelpump (via the ECU) preventing it from getting fuel(pressure) and thereor running.
As I want to use the '95 loom (because of the internal fusebox) and don't have all parts for the immobilizer (key fobs) or know if they are correctly pared or if they function at all, I don't want to use the immobilizer and it's paired ECU (MNE101150), but use my old uncoded ECU (MNE101070 "cooper" or the MNE10140 "sprite")
So I don't want to bypass the immobilizer (as in: using an ECU with an immobilizer code without the imobilizer).
I want to use a standard '93 ECU (that has always ran without an immobilizer) in combination with a '95 loom (that host the connection for an immobilizer) without installing the immobilizer. Can this be done and if so, need I make any alteration(s) to the loom to operate/run this '93 mini (and non immobilzer aware ECU) without the immobilizer?
sources:
ROVER MINI ANTI-THEFT ALARM - WIRING DIAGRAMS PAGE 20.PDF
http://www.theminifo...ttach_id=193837
As the car is completly in bits, I have no means to test this and rebuilding a SPI without is already daunting by itself (will it start? If not what could be wrong) without the ingredient of an immobilizer and ECU without history or any keyfobs.
(Hmm, this must be the topic on this forum that has the most times "immobilizer" in it ;)
(If you have information that could help/you want to share that you find to sensitive for an open forum, please feel free to contact me via PM).
Kind regards,
Johnmar
(The Netherlands)
Edited by Johnmar, 02 October 2020 - 10:04 AM.
