Changing Timing Gears/chain
76 replies to this topic
#16 maystro
maystro
  • 298 posts
Posted 26 September 2020 - 11:21 AM
Thanks Spider,
I have to take ownership of this not you.
My 1981 motor should have the A+ timing cover plate.  I thought I even saw the bulge.   Anyway all good.  I'm  glad I don't have the tensioner and that the guy I bought this motor actually put a double row timing chain in.
I'm always ordering parts anyway so thinking of getting new lifters.
Brad
#17 Ethel
  • 26,060 posts
Posted 26 September 2020 - 12:06 PM
I'd keep the original cam followers unless they're obviously past it, for the same reason they shouldn't be mixed up. If they're badly worn the cam could well be too.
I think having the dots align on no. 4 just made it a bit easier to install the dizzy drive on the production line by sitting the cam lobes more out of the way.
#18 gazza82
gazza82
  • 3,019 posts
  • Local Club: TMF+
Posted 26 September 2020 - 01:19 PM
Nick I put this new dizzy in recently and when I did it I thought it was as at TDC and the rotor was at 2 oclock.  So spark plug wire 1 is firing at 2 oclock not 8 oclock.
Do the dots always align up at TDC on the compression stroke?  Maybe I put the cam 180 degrees out 18 years ago.   Is this possible which I find hard to beleive since my motor has been running so well?
Brad
The dots line up every 2 revolutions ... try another full turn and check which cylinder is firing (both valves closed)
#19 maystro
maystro
  • 298 posts
Posted 27 September 2020 - 08:34 AM
Brad
Gazza,  no matter how many times I rotate the engine the dots won't align at TDC on no.1. They align at the firing stroke on no.4 like Spider stated.
Maybe it was a design feature they factored in like Ethel said?
Brad
Edited by maystro, 27 September 2020 - 08:35 AM.
#20 johnv
johnv
  • 498 posts
  • Local Club: FDMC
Posted 27 September 2020 - 09:04 AM
Can I ask an idiot question? I thought that when the dots lined up the cam was timed in.. At, say, 106° before tdc, so no1 piston will not be at tdc but coming up to it??
#21 Spider
  • 15,106 posts
Posted 27 September 2020 - 09:15 AM
I don't know why it is, but that's how the A and I think B Series are - when the dots are lined up No. 1 has finished the exhaust cycle and starting inlet, No. 4 is firing.
Actually, no.
No. 1 will be at the top of the Bore and only just starting an Inlet Cycle, The figures like 1060 and 1100 etc refer to when No. 1 Inlet is at full Lift, which is when the piston is some way down the bore.
#22 johnv
johnv
  • 498 posts
  • Local Club: FDMC
Posted 27 September 2020 - 09:21 AM
Actually, no.
ok so it is true to say that when the dots are in line no 1 will be at tdc ...
#23 Spider
  • 15,106 posts
Posted 27 September 2020 - 09:55 AM
Actually, no.
Usually TDC refers to the Piston not only being at the top of the bore, but also on the Firing Stroke, so in this case, no.
#24 johnv
johnv
  • 498 posts
  • Local Club: FDMC
Posted 27 September 2020 - 10:03 AM
Sorry, to be clear, when the dots are aligned number 1 will be at tdc on the firing stroke?
#25 maystro
maystro
  • 298 posts
Posted 27 September 2020 - 10:10 AM
No mate,  that is what I just found not to be the case.
Read thru the thread.
Brad
Edited by maystro, 27 September 2020 - 10:23 AM.
#26 johnv
johnv
  • 498 posts
  • Local Club: FDMC
Posted 27 September 2020 - 10:16 AM
No mate,  that is what I just found to be the case.
Brad
I tried but I got too confused!
#27 Spider
  • 15,106 posts
Posted 27 September 2020 - 10:21 AM
No.
Number 4 Cylinder is.
#28 maystro
maystro
  • 298 posts
Posted 27 September 2020 - 10:29 AM
Brad
I hear you mate ;-)
#29 maystro
maystro
  • 298 posts
Posted 27 September 2020 - 11:28 AM
Here is a tip also if anyone is doing a timing chain replacement.
Replace the engine mount on the radiator side with a captive nut engine mount.
Have you ever tried to put a spanner on the inside back nut which keeps turning?
Sheesh
#30 Ethel
  • 26,060 posts
Posted 27 September 2020 - 11:35 AM
For balance reasons the crank is symmetrical 1& 4 are at tdc when 2 & 3 are at bottom tdc. Tdc is a convenient datum (piston's highest point*) to use to align the rotating parts in the correct angular position. The valve timings are fixed by the cam lobes, so there are 2 possible correct positions because the crank will pass tdc twice before the cam does a lap to get back to where it started. It's arbitary whether 1 or 4 is starting its power stroke, but making a choice means you can add extra datums (pulley dot marks) so you know the cam's position to get the distributor timing right too.
To time a cam finding the crank tdc first allows to to turn it the correct amount so when you get the cam lobe to its tdc the crank & cam will be optimally synchronised.
Apologies if that sounds patronising, not trying to teach anyone to suck eggs - just running through the thought process that helps me get my head round it.
*actually the crank won't be vertical unless the bore axis is directly above the crank axis, but datums are just somewhere obvious & reliable to measure from.
