My New (Old) Mini Keeps Cutting Out
149 replies to this topic
#136 Marc13
Marc13
  • 216 posts
Posted 15 November 2020 - 02:59 PM
I've had the timing checked, which was out and also someone has looked over a few things and thinks the fuel pump is dodgy.
What would be a good replacement fuel pump - carb is a HIF44 SU?
#137 I hate Brian
I hate Brian
  • 782 posts
Posted 15 November 2020 - 03:11 PM
Hi I use a  ELECTRONIC FUEL PUMP FACET STANDARD SOLID STATE SS501
http://www.minispare...px|Back to shop
Best thing to do is also have a pressure regulator by Filter King hope this helps https://www.ebay.co....LkAAOSwQvhZhHMH
Edited by I hate Brian, 15 November 2020 - 03:14 PM.
#138 Marc13
Marc13
  • 216 posts
Posted 15 November 2020 - 03:18 PM
Hi - thanks for that.
Couple of questions...whats the pro's and cons of using an electronic fuel pump?
Where would the pressure regulator fit? And what does help/improve?
#139 I hate Brian
I hate Brian
  • 782 posts
Posted 15 November 2020 - 04:49 PM
Hi I fitted my electric fuel pump on the subframe left hand side and the regulator /filter in the engine bay where ever you have space usually near the windscreen wiper motor  the pressure regulator give precise fuel pressure to the carb and also the filter is in an easy position to change as and when.
As for pro's a lot of people on here talk about if the mechanical pump fails then you have petrol in your oil which could be really bad for the engine, cons cost and installing
Edited by I hate Brian, 15 November 2020 - 04:54 PM.
#140 Marc13
Marc13
  • 216 posts
Posted 15 November 2020 - 07:06 PM
Thanks.
Is there a downside if i go for the competition pump, rather than the standard?
Just thinking - a possible upgrade in the future was to go to twin carbs, rather than the single carb thats on there at the minute. And I think twin carbs would need the competition pump? But for the here and now I will be sticking with the single carb - so just wondered if the competition electronic fuel pump would be ok?
Also - re the fuel pressure regulator. Its say weber dellorto carb. Mine is a Hiff44 SU - is that ok?
#141 GraemeC
GraemeC
  • 7,432 posts
Posted 15 November 2020 - 07:30 PM
The other pumps just provide more fuel and higher pressures. Not needed on a Mini.
Why would the twin carbs need a competition pump? Same engine, same fuel demand.
#142 Marc13
Marc13
  • 216 posts
Posted 15 November 2020 - 07:41 PM
Just learning all this stuff........If its the same fuel demand from 2 carbs as 1 carb, why would coopers/cooper s's have 2 carbs rather than 1?
#143 GraemeC
GraemeC
  • 7,432 posts
Posted 15 November 2020 - 08:12 PM
The carbs don’t demand fuel, the engine does.
Twin carbs tend to give a better throttle response and a different torque delivery.
#144 Marc13
Marc13
  • 216 posts
Posted 15 November 2020 - 08:23 PM
ahh ok. But 2 carbs wouldn't need more fuel....as in the amount of fuel that one carbs wants, 2 carbs now want....so twice as much. Or it doesnt work like that?
In any case, whether I stick with the one carb, or upgrade to 2 carbs. The standard electronic fuel pump is fine?
Would you say that an electronic fuel pump and fitting a regulator is generally the best option?
#145 Marc13
Marc13
  • 216 posts
Posted 16 November 2020 - 08:12 PM
If i go down the electric fuel pump route, will i need blanking plates etc for the existing fuel pump?
#146 cal844
cal844
  • 9,619 posts
  • Local Club: TFMOC
Posted 16 November 2020 - 08:16 PM
Blanking plate, gasket and 2 bolts
#147 Marc13
Marc13
  • 216 posts
Posted 16 November 2020 - 08:34 PM
Mini spares website do the job?
#148 I hate Brian
I hate Brian
  • 782 posts
Posted 16 November 2020 - 09:08 PM
Hi try this  http://www.minispare....aspx|Back to
http://www.minispare...ck to catalogue
Edited by I hate Brian, 16 November 2020 - 09:10 PM.
#149 Marc13
Marc13
  • 216 posts
Posted 16 November 2020 - 09:56 PM
Awesome - thank you
#150 I hate Brian
I hate Brian
  • 782 posts
Posted 17 November 2020 - 07:49 AM
No problem anytime
