South African Clubby
9 replies to this topic
#1 Chris.Williams
Chris.Williams
  • 679 posts
Posted 18 September 2020 - 04:06 AM
Hi all, picked up the above a couple of weeks ago, what can Anyone tell me about these motors, seems to be a 1275 but with a 1098 engine number, I’ve read bits and pieces about short stroke this and that, hoping for a bit more insight.
Chris
#2 Vinay-RS
Vinay-RS
  • 2,115 posts
Posted 18 September 2020 - 06:28 AM
Hey Chris, congrats on the purchase! Could you post a pic of the engine? Also does it have a riveted or stamped engine number? This would determine whether it is a 1098 Clubman, a GTS (1275) or a 1275 E. Also the engine bay and engine number would make it clearer to identify the model. A lot of local Minis (especially 1098s) had their engines swapped because you can't get pistons/rings for those engines (I believe).
Specs:
1098:
Bore: 70.64 mm
Stroke: 69.85 mm
Compression ratio: 8.0:1
1275 (GTS):
Bore: 70.64 mm
Stroke: 81.28 mm
Compression ratio: 9.75:1
1275 (E):
Bore: 70.64 mm
Stroke: 81.30 mm
Compression ratio: 9.4:1
That's the tech specs from a local data source (Ryno Verster's A South African Mini Story).
Hope that helps :)
#3 Chris.Williams
Chris.Williams
  • 679 posts
Posted 18 September 2020 - 07:42 AM
Hey Vinay, thanks for your kind words.
I have these pictures
Engine number starts 10h702e
Attached File  365C7662-0748-4702-867D-9DFAE6E63697.jpeg   131.22K   1 downloads
Attached File  62727E61-A079-475F-9776-49095B697CC4.jpeg   120.32K   1 downloads
#4 timmy850
timmy850
  • 3,327 posts
  • Local Club: MITG
Posted 18 September 2020 - 08:39 AM
If it's the 1098 short stroke crank (unique to the South African cars) you can modify the engine to be a 1071 Cooper S style screamer. In factory spec though they had giant top pistons to make up for the shorter stroke
You'll need to add some longer 6" rods OR cut the top of the block down 1/4" to work with the usual 1275 pistons & use some small bore pushrods. They are a popular engine over on the mk1-forum
I'm lucky enough to have an SA1100 crank for my next engine project thanks to Jared  :lol:
#5 Vinay-RS
Vinay-RS
  • 2,115 posts
Posted 18 September 2020 - 08:56 AM
Yup! That's a 1098 engine number and what looks like a Clubman chassis number. Not sure if the engine was that colour though from the factory.
#6 Chris.Williams
Chris.Williams
  • 679 posts
Posted 18 September 2020 - 09:14 AM
So is this thing worth my time to get back on the road you think?
#7 Vinay-RS
Vinay-RS
  • 2,115 posts
Posted 18 September 2020 - 09:25 AM
Assuming the engine is fine, it would be nice to put it right. Those engines are really smooth. They were the most sold Minis locally (they sold around 10000 of them), but many have been used for stock car racing/chopped up/rusted away, and there aren't that many tidy examples even locally.
#8 Chris.Williams
Chris.Williams
  • 679 posts
Posted 18 September 2020 - 10:09 AM
Here are the pictures I have so far
Attached File  56A9A37E-4BA1-4C39-84AA-4F104B8CB59D.jpeg   58.97K   1 downloads
Attached File  09F1931B-7D2D-41E6-8A19-8578C1D80D50.jpeg   59.8K   2 downloads
Attached File  75F017CB-CBBA-459B-94F7-02909FB83A89.jpeg   60.92K   2 downloads
Attached File  514A34F6-8B16-429F-86AB-68D11D1B09C1.jpeg   56.7K   1 downloads
Attached File  EDDD2256-7C06-4C44-BBE0-257E7C7E6543.jpeg   103.1K   1 downloads
Attached File  390C0913-D019-4AC6-A158-6696CCFC27F1.jpeg   74.2K   2 downloads
#9 Vinay-RS
Vinay-RS
  • 2,115 posts
Posted 18 September 2020 - 10:14 AM
Those front seats look original and the shell looks really solid too.
#10 Chris.Williams
Chris.Williams
  • 679 posts
Posted 18 September 2020 - 08:14 PM
Yeah, couple of pinholes in the passenger sill, some of the body filler is looking tired.
Will strip all that off and redo what’s needed. Prime, paint and reassemble.
