Fwd R1 mini
202 replies to this topic
#151 Ethel
  • 25,897 posts
Posted 24 July 2007 - 04:24 PM
Pretty sure they claim the Mini one (if not all) is sealed on the Quaife website.
#152 R1mini
R1mini
  • 1,387 posts
Posted 24 July 2007 - 05:12 PM
I know what they are talking about now, they are non maintenance and sealed, but they are not sealed from oil
david
#153 Ethel
  • 25,897 posts
Posted 24 July 2007 - 05:33 PM
Sure I read a FAQ that suggested they are, something to do with oil recommendations.
Wouldn't it be an issue for the lifetime warranty otherwise - they'd be at the mercy of any C**p sloshing round in your gearbox or low oil level?
#154 roofless
roofless
    Sticker Pimp
  • 7,215 posts
  • Local Club: central minis
Posted 24 July 2007 - 05:40 PM
from the horses mouth.......
The Austin Rover Mini Cooper S Quaife ATB differential has many benefits over a standard open differential, including maximising traction and minimizing wheelspin, eliminating torque steer and snatching in front wheel drive cars compared to conventional LSD units, and a maintenance-free design which retains the standard oil lubrication.
#155 R1mini
R1mini
  • 1,387 posts
Posted 24 July 2007 - 05:44 PM
what can I say, I have three of all together, two of them have large holes for oil, the bike engined version is mostly sealed with small holes which are plugged with bolts, on of them is a grease nipple for filling
If they have low oil or C**p oil there will be no warranty
David
#156 roofless
roofless
    Sticker Pimp
  • 7,215 posts
Posted 24 July 2007 - 05:51 PM
David
want to sell one? I need one for for my pro-motive conversion ( pending ) theyve quoted an extra £575.00 to supply an LSD which I believe is a quaife unit.
agree regarding warranties - it'll assume you take good care of the unit in operation.
#157 R1mini
R1mini
  • 1,387 posts
Posted 24 July 2007 - 06:01 PM
They are not for minis, fiesta/escort based I'm afriad
David
#158 Ethel
  • 25,897 posts
But does that imply standard lubrication of the diff or that the car it's fitted to needs no modification?
I have had another look on their site and it does look like there are some oil
ports :P
#159 Taisto
Taisto
    Just On Tickover
  • 7 posts
Posted 09 September 2007 - 09:30 AM
Hi.
I have R1 engine mini and i have some proplems with generator... Too much load:lights,fan,heater,injection,compressor(pneunematic gears) and battery is dead after one day driving.
Generator pull out 14.5v in 5000rmp/min without load. I think at generator is ok , but it is too small for car? Do you have tricks to get more power from generator? Reculator mod or something?
Sorry poor english, but i am from Finland and i learn all this from McCyver....
#160 supermotolee
supermotolee
  • 1,120 posts
Posted 09 September 2007 - 09:50 AM
what battery are you using the bike one or a car one? mcgyver rocks!
#161 Taisto
Taisto
    Just On Tickover
  • 7 posts
Posted 09 September 2007 - 10:30 AM
I have try both. Now i have 20ah gel-battery(bike). It is best of all. What battery you use? 10ah bike orginal?
#162 koss
koss
  • 1,399 posts
  • Local Club: The Greenbank working mens social club
Posted 09 September 2007 - 12:53 PM
I use a 500Ah on my r1 mini with no problems.
You could easily use a car alternator by asking TTS performance parts for one of there pulleys off the supercharger kits.
Attached File  SuperMontage.jpg   40.33K   93 downloads
#163 supermotolee
supermotolee
  • 1,120 posts
Posted 09 September 2007 - 02:54 PM
check the charging under different conditions i have worked on bikes for a while (mostly hondas mind) and vfr 800's used to not charge as well if at all when the reg rec got hot to the touch also check continuety from each wire off the alternator to ground sometimes the windings fail and short, if you get a workshop manual it should also tell you how to check the unregulaed output ... thats all i can think of at the moment
i use a car battery same as i used on my a series but i've not really driven the car properly yet
#164 Taisto
Taisto
    Just On Tickover
  • 7 posts
Posted 09 September 2007 - 03:51 PM
Not bad idea that car alternator, but if you have get it work without that then i can too :withstupid: .
I have re-wired reculator + and - to direct to main. Its help lite, its ok if lights is on but when fan start voltages go under 13v... And fan is on about 80% of time. Its kill battery.
Koss ? Its that 500ah normalcar battery or bikebattery? Yamaha R1 orginal is only 10ah so that 500ah is extralarge???
My mini
#165 koss
koss
  • 1,399 posts
Posted 09 September 2007 - 05:13 PM
My mini
Yes its a car battery off a big diesel. I have an electric motor for reversing, that needs lots of power.
The bike battery is only good for bikes.
Another option is to have two battery's on a split charge system one for engine and one for the car.
With everything electrical going on my car at the same time it can demand more than 100A.
