While the Rear Subby is off, and I'm replacing the front to back brake pipe, I thought I might as well replace the fuel pipe.
The car is a 1991 Cooper Carb, and I'll be keeping the HIF44, but the engine will be a "fast road" 1330.....
So my questions are:
1) Do I replace the fuel pipe with 1/4 OD pipe, or is there any advantage with increasing the diameter?
2) Is copper pipe OK, or is Copper Nickel preferable?
3) I was thinking of fitting a Fuel Filter on the rear subframe, between the Tank and the solid fuel pipe. Is that the best place, as close to the tank as possible? I might fit one before the Carb as well...
4) Is there any benefit fitting a fuel shut off tap after the fuel tank?
Cheers!
