Best Technique To Straighten Bent Floorwells (From Bad Jacking)?
10 replies to this topic
#1 riczito
riczito
  • 54 posts
Posted 10 September 2020 - 11:51 AM
Hi all,
I had some work done on my car recently, and apparently the people who did it weren't Mini specialists. Because they committed a newbie error, and jacked the car up in the wrong way, from under the front footwells. As a result, the footwells are somewhat caved in, bent upwards in that area on both sides. I think the floor can probably be redressed, but I'm wondering what the best technique is? Does anyone have any experience in this domain? Any videos out there?
Thanks,
Ric
#2 RustyAutoCityE
RustyAutoCityE
  • 320 posts
Posted 10 September 2020 - 12:01 PM
Sorry to hear about the damage, have you been in touch with the garage that caused it?
You could always try the old fashioned lump of wood and a mallet method from inside the car.
#3 riczito
riczito
  • 54 posts
Posted 10 September 2020 - 12:09 PM
I have, yes. They said they'd fix it. Problem is, they're a long way away from me, and I don't know when I can find the time to drive all the way out there. I was thinking I might do it myself. Lump of wood and a mallet, you say? Hammered down from inside? Does that work OK? For some reason I thought it needed to be pulled out from underneath.
#4 RedRuby
RedRuby
  • 1,201 posts
  • Local Club: No
Posted 10 September 2020 - 12:29 PM
As rustyauto suggests plus you could put some timber underneath spanning the damaged area supported lightly by a jack so when working from inside you won’t end up bowing it in the opposite direction.
#5 slidehammer
slidehammer
  • 1,194 posts
  • Local Club: LSMOC
Posted 10 September 2020 - 12:30 PM
When I have straightened them out, I have done the above with a block of wood and a large hammer. It looks like they have mistaken the slinger bracket for a jacking point. That will be harder to straighten out as it should run parallel to the floor with a small gap. Maybe you could carefully leaver that down with a large flat bladed screwdriver.
#6 RustyAutoCityE
RustyAutoCityE
  • 320 posts
Posted 10 September 2020 - 12:32 PM
Nice they offered to sort it out at least.
Depends on how perfect you would like the end result I guess. Although not a Mini, I have used the wood and mallet on the floor of a Nova. Came out ok.
Regardless of what method you use, make sure that seam is well protected incase water gets in there.
#7 g0myw
g0myw
  • Just Joined
  • 108 posts
Posted 10 September 2020 - 12:37 PM
I had the same scenario when getting new tyres.
The young d1ckH3@d just trolley jacked both sides.
{the mini was out of sight for me}
I'm sure we've all learnt from this .!
Anyway block of wood & careful use of a club hammer.
Edited by g0myw, 10 September 2020 - 12:38 PM.
#8 imack
imack
  • 2,103 posts
Posted 10 September 2020 - 02:11 PM
Check this out:
https://youtu.be/BXlnQgeTJGk
#9 sonscar
sonscar
  • 2,995 posts
Posted 10 September 2020 - 02:14 PM
Not confined to Minis either.The fitter was about to jack my wifes Kia under the sill seam.When I stopped him he used a superior tone That is the jacking point Sir.Yes I said but only with the factory jack which has a plastic lined slot to fit over it.No training is my Guess.Steve..
#10 paul748
paul748
  • Just Joined
  • 80 posts
Posted 10 September 2020 - 06:32 PM
Same thing happens with MOTs.
The problem is that the modern lifting equipment is not suited to the floor of the classic minis (and other old cars).
At my last MOT, the tester showed me the problem. He was very careful but I could see that it was very difficult to get a safe lift without causing some damage, especially at the front.
#11 riczito
riczito
  • 54 posts
Posted 11 September 2020 - 12:21 PM
Thanks, that was really interesting. Although I think I'll have to content myself with the hammer technique, as I don't have a lift. I've watched quite a few of davejaguar66's videos. They're a gold mine of useful info!
