I'm hoping someone can help.
EFB16C0C-64DB-4EDE-934C-D876F96F5BC4.jpeg 99.17K
2 downloads
Posted 05 September 2020 - 07:37 AM
2 downloads
Posted 05 September 2020 - 08:53 AM
Posted 05 September 2020 - 09:34 AM
With the windscreen fitted it is not easy to remove the dash top and can result in more damage than it is worth......can you not repair the windscreen demister vent with duct tape or similar, they are only plastic in later Minis and not worth a big effort to replace if you can repair from below in situ so it does not leak air.
Edited by mab01uk, 05 September 2020 - 09:35 AM.
Posted 05 September 2020 - 10:22 AM
I'll guess the end the screw goes through has broken off?
They're not the best made things & tend to leak as much air as the deliver to the screen anyway.
You could use aluminium tape to clag it on to the dash rail proper & attach some sort of brace to the pointy end of the screw by pushing on a spire nut or star washer
Posted 05 September 2020 - 12:42 PM
Thankyou for your replies, very helpful and informative. I never imagined that fitting a new vent would involve so much effort.
The broken one in my car has snapped off completely. I tried to secure it with tape but however much tape I used no air comes through the vent. I wouldn't be too bothered if it wasn't the driver's side.
Looks like a fun weekend project taking out the windscreen and dash top !
Posted 05 September 2020 - 01:06 PM
Posted 05 September 2020 - 03:47 PM
Later ones only have 3 bolts.
I bought a good used dash top and someone had cut the bolts down as well.
Hopefully, when I get to fit it the windscreen won't need to come out.
