1993 Mini Sprite Fuse Lf6 Location
electrical
25 replies to this topic
#16 zace66
zace66
  • 27 posts
Posted 22 September 2020 - 09:11 PM
OK - so all fuses and holders checked and working fine.
Anyone able to advise me if there is a cable going across the car to link the left and right sidelights?
#17 MikeRotherham
MikeRotherham
  • 976 posts
Posted 23 September 2020 - 10:54 AM
The wires for both sidelights and both headlights are joined with bullet connectors beneath the bonnet catch on the front panel.
Because of the exposed position and also the open ends of the bullet connectors people have lots of problems with bad connections, corrosion and the like.
Any problems with lights at the front. I would check these connectors first and clean them.
#18 gazza82
gazza82
  • 3,012 posts
  • Local Club: TMF+
Posted 23 September 2020 - 03:32 PM
I've not tried them yet, but I've been told the more modern "Japanese Bullets" are an improvement over the originals as they have better seals. I'm planning on getting some to try out when I re-loom my classic (which has similar wiring to the Mini).
The originals are open at the ends and moisture can get in .. although I guess you could shrink-wrap them too.
#19 zace66
zace66
  • 27 posts
Posted 24 September 2020 - 10:43 AM
what about the rear lights?
#20 GraemeC
GraemeC
  • 7,438 posts
Posted 24 September 2020 - 11:09 AM
Wires extend across from the behind the fuel tank, along the rear edge of the boot floor (along the hinge panel).
#21 zace66
zace66
  • 27 posts
Posted 24 September 2020 - 07:17 PM
Thanks, but im guessing the chances that front and rear cables across causing nearside lights front and back to fail is going to be rare.
#22 MikeRotherham
MikeRotherham
  • 976 posts
Posted 25 September 2020 - 07:06 AM
Your original post mentioned that sidelights on the RH side weren't working. Your post above mentions nearside lights. Is this the same original problem or has it changed to the other side?
#23 sonscar
sonscar
  • 2,995 posts
Posted 25 September 2020 - 07:32 AM
Bite the bullet time,remove dash,start at fuse as last known voltage and unravel the loom to find where the Clocks rear and front light wires are teed.The fault has to be before this to stop all of them.Seems daunting but guessing is not fixing it.Kind of therapeutic I find.Steve..
#24 MikeRotherham
MikeRotherham
  • 976 posts
Posted 25 September 2020 - 10:50 AM
Have the lights ever worked since you've owned the car?
Do the lights currently not working have LEDs in them?
#25 gazza82
gazza82
  • 3,012 posts
  • Local Club: TMF+
Posted 25 September 2020 - 03:29 PM
Errr ... no. Especially fronts where the wiring is more exposed to elements .. check the bullet connectors that join left to right.
#26 zace66
zace66
  • 27 posts
Posted 26 September 2020 - 05:23 PM
No - none worked when we first inherited it - changed all the fuses and most things worked
we have replaced the front lights with the LED/ring/etc - all work except drivers side sidelights front and back
We know there is a short somewhere as the rear light dims on the left when braking.  Ive not had chance to look at that yet.
