Brake Master Cylinder Rebuild/disassembly 1987 Gmc227
brakes
24 replies to this topic
#1 Harwoods
Harwoods
  • 17 posts
Posted 30 August 2020 - 03:29 PM
Once again we have been stumped at rebuilding part of our 1987 Mini Mayfair while repairing the master brake cylinder GMC227 shown below as the rear circuit was completely dry:
As you can see we have removed the cir-clip and pulled the piston rod that connects to the pedals out. But we were expecting the spring loaded pistons to push their way out of the cylinder. This has not happened and there is clearly something catching/knocking into that is not allowing the pistons out.
There is a spot on the top of the cylinder that may just be casting but our's is rather dirty so hard to tell if there's something that needs undoing in the top. There is definitely nothing catching the bottom.
We have researched online and found nothing relating to this particular brake master cylinder and have only been able to cross reference to older/newer similar versions with no luck on how this comes apart.
Any help/advice or documents for disassembly we would be very grateful of.
Further pictures:
A smaller issue we are having is removing the pin that holds to reservoir on as it is rather stubborn and clearly the tank fowls one side of the bolt making is rather a hassle to navigate hammering it through. Advice here is welcome.
As usual thanks again all, very much appreciated.
#2 nicklouse
  • 18,574 posts
Posted 30 August 2020 - 03:48 PM
Rust will be holding it in place. Push in and clean.
IIRC that is a roll pin that needs pushing out.
#3 JXC Mini GT
JXC Mini GT
  • 842 posts
Posted 30 August 2020 - 04:30 PM
I have just removed a master cylinder form my 1980 Mini GT which I believed was faulty, however it turns out that the problem i had was the brake limiter valve.
If you would like the master cylinder drop me a PM, I am based in Tunbridge Wells, Kent
#4 Harwoods
Harwoods
  • 17 posts
Posted 30 August 2020 - 04:32 PM
Just to confirm then, you're talking about the piston inside is being held in place with Rust? Are you confident there's nothing else that needs undoing/releasing? Otherwise it'll need a lot of elbow grease by the feel of things, seems to be knocking hard into something when releasing the spring pressure after compressing and releasing.
#5 nicklouse
  • 18,574 posts
Posted 30 August 2020 - 04:37 PM
yes
#6 Harwoods
Harwoods
  • 17 posts
Posted 30 August 2020 - 04:51 PM
Edited by Harwoods, 30 August 2020 - 10:28 PM.
#7 Harwoods
Harwoods
  • 17 posts
yes
 That is a different brake master cylinder though, do you have any experience with GMC227?
#8 nicklouse
  • 18,574 posts
Posted 30 August 2020 - 05:00 PM
they are all basically the same. see your Haynes manual.
#9 GraemeC
GraemeC
  • 7,438 posts
Posted 30 August 2020 - 05:02 PM
It is, but yours will come apart in the same way and have the same rusty, mucky detritus stopping the piston coming out.
Push it back in, clean the bore as much as possible, add plenty of lubricant and then keep working it against the spring and letting it pop back - they (usually) gradually come a little further every time and eventually pop out.
#10 Harwoods
Harwoods
  • 17 posts
Posted 30 August 2020 - 05:07 PM
Thanks for the confirmation, never want to break anything with these original parts. Will give that a go, does certainly seem like it's knocking into something rather solid and not scraping on rust but will see how we get on, Thanks again.
#11 GraemeC
GraemeC
  • 7,438 posts
Posted 30 August 2020 - 06:02 PM
At the bottom of its stroke it does build up a lot of crap - years of use and always wiping the bore to the same place does create quite a wall of muck
#12 absx2
absx2
  • 907 posts
£67.71 with the 7.5% discount.
This is without doubt the most important part of the car, i`m a total tight arse and it amazes me that people still think they are worth buggering around with for the price.
The part has failed due to corrosion wearing the seals, the bore will be filled with tiny pits and not so tiny score marks, yes you can replace the seals and it might go on for a bit but you have to ask is it worth it ?
#13 nicklouse
  • 18,574 posts
Posted 30 August 2020 - 06:03 PM
they do. as we have said push up and clean and then work it out with the spring.
#14 Spider
  • 14,838 posts
Posted 30 August 2020 - 06:47 PM
Then I usually bang them down on a block of timber and they come out pretty easy.
That will get the lower piston set out. There's usually a Pin behind the Upper Reservoir Seal that retains the Upper Piston.
#15 Spider
  • 14,838 posts
Posted 30 August 2020 - 06:57 PM
This might also help;-
The Pin I referred to above is item no. 3
To remove the Reservoir, it should just pull away, hinging on the Roll Pin, then slide it off to the side. It's only the Seals that hold it in.
Also tagged with one or more of these keywords: brakes
