One of the biggest problems with my Engine Re-Build so far is trying to work out which bolts are required where and which ones I have and which ones I don't.
I opted to clean up lost of the existing bolts and re-plate them and as I only have about 1/2 it's making things tricky.
Diff Output Covers
On the Diff can anyone confirm that the bolts for the Diff Output Covers are 5/16 x 1" UNC. On one side that's what I used
Timing Plate
I am a little lost with the Timing Plate, and as I am fitting a Duplex Timing Gear I won't be using the Tensioner so does that mean additional / different bolts to go in where the tensioner would normally go?
Some of the bolts go into the block and some screw into the timing plate itself, and on the Somerford Diagram some of the bolts are entitled Main Bearing Cap ???? Confused.
So with this in mind can anyone tell me what bolts / washers and lock washers I need?
I find the Mini Spares and Somerford quite tricky to work out what bolts are for what.
This is an A+ 1275 from a Mk 2 Metro (about F reg 1988/9), lots of these original bolts are flanged.
