123 Or Csi Distributor
Posted 19 August 2020 - 05:04 PM
Posted 19 August 2020 - 07:08 PM
I've been running a couple of CSI's for over 8 years now. I can't fault them. Easy to find cap and buttons for. They have a sensible choice of curves.
Posted 19 August 2020 - 07:40 PM
I've used both and prefer Swiftune's CSI. The 123 that I have is older and requires removal to change the curve, Swiftune's doesn't.
Posted 19 August 2020 - 09:10 PM
Posted 19 August 2020 - 11:01 PM
Posted 20 August 2020 - 12:47 AM
Whats the difference between the swift tune and normal csi?
There's a different set of curves in Swifties that better suit their Cams, and likely others, though, the 'standard' CSI will also go a long way here.
There's also an optional model available with the CSI for an Anti-theft device, where it needs a 'fob' (that come with it) in order to start.
Posted 20 August 2020 - 12:37 PM
We've been running a 123 in an MGA for years and it's been pretty good, but I have no means of comparing it to the CSI module. The downside to a 123 can be that it looks non-original which can be a turnoff for some people. Ours is an old model with a pretty backward way of setting the curves, from what I understand that system is now greatly improved and can even be done by Bluetooth on some models. You can also use the Bluetooth connectivity to drive a digital dash if you like, and use it to lock the system so it cannot be started without putting a PIN in first.
Posted 20 August 2020 - 02:59 PM
Posted 20 August 2020 - 07:12 PM
I'd like to suggest here, if you know what curve your engine needs, it would be far cheaper to buy a new distributor to suit or have one overhauled and set up for your requirements. While I find the CSI is great and I have no issues with the quality of them, they are frightfully expensive. I originally only went to these as new distributors with known reliable curves weren't available at the time I needed them and I didn't have time and the parts to re-curve another.
