Ignition System Issue After Rebuild
37 replies to this topic
#16 sonscar
sonscar
  • 2,997 posts
Posted 18 August 2020 - 07:05 AM
Just a thought,is the starter jammed in the engine?I had a similar thing when I changed the started relay for the wrong type.Steve..
#17 Mini 360
Mini 360
  • 4,933 posts
  • Local Club: Independent
Posted 18 August 2020 - 11:57 AM
Thank you all. I will take another look at it this afternoon. I'm not too concerned about the not turning over bit for now. I'm more concerned about NO electrics anywhere. No dash lights, can't switch on anything etc.
#18 GraemeC
GraemeC
  • 7,438 posts
Posted 18 August 2020 - 12:33 PM
I fitted a new battery which is showing perfect voltage
What do you call perfect voltage?  It should be 13.8V
I'd first suspect a flat battery and then a very bad short - on your photos of the ignition wiring 5 way plug, both the permanent live (brown) and ignition switched live (white) look like they have been overheating - this points to a short on the ignition circuit somewhere.
Edited by GraemeC, 18 August 2020 - 12:37 PM.
#19 Mini 360
Mini 360
  • 4,933 posts
Posted 18 August 2020 - 02:21 PM
I charged the battery overnight to confirm it's not the battery at fault. It's reading 13.6-13.8v consistently before and after the charge.
I'm getting this voltage at the 5 way plug you mention above, now. This is after cleaning up all connections to the starter solenoid and coil to ensure they all have good connections.
I have a Smith's voltmeter on my dash which also shows no reading, regardless of ignition position.
I've checked resistance across the coil and it reads 1.3ohms which I believe is normal too.
#20 gazza82
gazza82
  • 3,013 posts
  • Local Club: TMF+
Posted 18 August 2020 - 03:44 PM
Tried "hot-wiring" back of ignition switch?
Perm live (brown?) to white (ignition activated)
Then it should be white with red trace to solenoid activation.
That would eliminate the ignition switch (which is what it sounds like may be your problem)
#21 Mini 360
Mini 360
  • 4,933 posts
Posted 22 August 2020 - 01:48 PM
Tried shorting the brown to white with an offcut of wire. Nothing.
Tried shorting brown to white with red trace with an offcut of wire. Solenoid made clicking noise.
From this I presume there is an issue with ignition.
#22 GraemeC
GraemeC
  • 7,438 posts
Posted 22 August 2020 - 02:28 PM
No - this should make the engine turn over - independent of the ignition.
Starter relay possibly?
#23 Mini 360
Mini 360
  • 4,933 posts
Posted 22 August 2020 - 03:22 PM
Taken it out and replaced with another I have in stock.  I have then tested voltage at the starter solenoid and it has no reading at all.  Put original relay back in and gets full voltage from the battery.  Think starter relay is fine.
#24 Mini 360
Mini 360
  • 4,933 posts
Posted 22 August 2020 - 03:51 PM
Here is the wiring I have at the starter solenoid, coil and alternator.
#25 sonscar
sonscar
  • 2,997 posts
Posted 22 August 2020 - 06:45 PM
It looks like the main battery wire is touching the casing of the solenoid.Where is the white red at the starter?Is the starter stuck in mesh?Steve..
#26 mini-mad-mark
mini-mad-mark
  • 849 posts
  • Local Club: northants wot no brakes
Posted 22 August 2020 - 07:35 PM
White red goes to the starter relay I think not to the solenoid/starter? - If you can see it the picture the brown/red goes to the solenoid large terminal
No help to the OP though.
#27 Dusky
Dusky
  • 5,322 posts
Posted 22 August 2020 - 07:49 PM
A voltage test doesnt prove that a battery is good. I work in a parts shop. I see loads of batteries at 12.5v with next to 0 CCA.
#28 GraemeC
GraemeC
  • 7,438 posts
Posted 22 August 2020 - 08:20 PM
That white/black on the alternator is not right - remove it and try again.
#29 Mini 360
Mini 360
  • 4,933 posts
Posted 25 August 2020 - 07:02 PM
Tried this. No such luck!
#30 Mini 360
Mini 360
  • 4,933 posts
Posted 28 August 2020 - 02:01 PM
Anyone any ideas? I'm no further forward and still have a car that has no ignition let alone turning over. Losing my patience with the dam thing now!
