Van Floor Options - M-Machine Vs Heritage
4 replies to this topic
#1 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,078 posts
Posted 15 August 2020 - 06:14 PM
I'm going to have to replace the whole floor on my mini van and probably the toe board too, I'm trying to find the best option, either A - buying a full m-machine floor or B - buying a saloon heritage floor, extension piece, sills, heelboard etc or c - buying a magnum van floor and buying the sills, heelboard etc.
Option A - m-machine - roughly £750 +postage
Pro's - it's already welded on a jig so know it's square etc
Con's - it's 2 floor half and a tunnel spot welded together so have the seams for rust traps
          - Not knowing how well the seams are rust protected, if at all?
Option B - Hertage - around £550 + postage
Pro's - It's mainly one full panel
        - Can treat all the seams with what I want
Con's - Have to weld it yourself with no jig
         - Spi floor so has one floor flute running down the full length of the floor
         - have a seam at the back where the mani floor attaches to the extension piece
Option C - Magnum - roughly £690 + 2 x postage
Pro's - Full floor panel
          - Unsure on quality and thickness of steel (usually slightly thinner than heritage and m-machine)
          - I think they only do round tunnels currently?
So has anybody had experience of the above options? Any tips for fitting it? I'm going to brace it all and portably put a couple of datums like the front and rear subframe mounting holes.
I very nearly bought the M-machine one yesterday until I saw they aren't one piece (I forgot to ask about rust protection they apply between the seams when I rang them)
#2 MrE812
MrE812
  • 39 posts
  • Local Club: ELMOC
Posted 15 August 2020 - 07:10 PM
Hey Alex,
In my limited experience, replacing one panel which is pre-assembled will be easier than assembling the jigsaw yourself (see Project Binky).
You'd still need to brace the shell and possibly make reference points to align with the floor.
I sourced half floors for my estate through M-Machine along with some heritage panels too.
Doreen would see you right I'm sure.
I would also suggest you assume nothing is protected against corrosion and treat all joints as a matter of course.
The coating on most panels is a courtesy to shipping and I've certainly had to sand back to bare steel to remove corrosion under the e-coat.
A good dose of etch primer and/or paint and seam sealant before more primer etc should be the ticket.
Other experts will be along to advise shortly I'm sure.
#3 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 15 August 2020 - 07:27 PM
I had this dilemma on a pickup I restored.
I ended up ordering the m machine floor but immediately sent it back. Not sure if it was just a dodgy one but i would describe it as being a scruffy patchwork quilt.
I ended up going for the heritage saloon floor, traveller/estate extension piece and then van sills and it worked out perfectly.
Like you pointed out, it has the injection pressing but is a small price to pay if you want a factory looking finish.
I had no issues getting the extension to line up. All you have to do is cut the return off of the back of the floor pan.
You don't need a jig, just build it all up on the car.
Here is how I did it, scroll down towards the end of this page for the start of the process.
http://www.theminifo...of-wight/page-4
Ben
#4 alex-95
alex-95
  • 6,078 posts
Posted 15 August 2020 - 08:44 PM
Hey Alex,
Cheers, Thats what I was thinking being pre-assembled and would save time. I did ring Doreen and she was very helpful.
Definitely going to be coating up the panels and doing it as i fit them, I learnt that after doing my saloon project >_<
Ben
Thanks Ben, Thats very Useful! I'll definitely be following that thread when I start it. I did think you had done a full floor but couldn't find it. I did see minimikej's estate thread that he had problems too. I think that makes up my mind on what way to do it though looking at your work. A friend of mine has just done similar on his clubman estate and said it wasn't too bad a job. I was going to ask if you would replace the toe board before or after the floor but your thread answers that :lol:
It's going to be another big order from minispares  O_O
I'll probably have loads of questions on bits you've done when I start doing it, if you don't mind ;D
#5 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 16 August 2020 - 08:27 AM
No problem Alex.
