Reinforcing Lower Subframe Mounts On The Toe Board
6 replies to this topic
#1 Uncle Bobby B
Uncle Bobby B
  • 13 posts
Posted 13 August 2020 - 05:40 PM
Hi all,
Does anyone know what the reinforcement plate ideally looks like when reinforcing the subframe mounts on the toe board? I would like to solid mount my front subframe on my mini project but I am unsure how big it needs to be, what shape, gauge of the metal etc.
How also do you prevent rust forming between the two plates?
#2 Ethel
  • 26,820 posts
Posted 13 August 2020 - 05:45 PM
I'm sure there's a topic with plenty of piccies. Try  doing a site: search of TMF with google
#3 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,189 posts
  • Name: Neil
Posted 13 August 2020 - 05:51 PM
Try this one
http://www.theminifo...ounts-allround/
#4 Ethel
  • 26,820 posts
Posted 14 August 2020 - 07:22 AM
...and
http://www.theminifo...or-solid-subby/
#5 Cooper Mac
Cooper Mac
  • 222 posts
Posted 14 August 2020 - 07:57 AM
This is what I have just done with mine:
I ordered some 125 x 125 x 3mm Steel plate of eBay, and cut out the middle so that the solid mount would fit inside. I also had some 3 x 30mm strip that was welded to the bottom edge to bolt to the floor. This was the mounts tacked together for a trial fit on the car:
I then drilled some 8mm holes in the plate and then offered this up to drill through the floor:
When they were all painted and ready to assemble, the wax was removed from the toe board and everything was degreased and dried. I then used Tiger Seal between the mount and the Toe Board, and inside the car, I used some M8 x 50mm penny washers to help spread the load. These again had Tiger Seal on them to help keep the water out!
#6 Ethel
  • 26,820 posts
Posted 14 August 2020 - 10:39 AM
Nice lateral thinking.
#7 Uncle Bobby B
Uncle Bobby B
  • 13 posts
Posted 17 August 2020 - 08:06 AM
Thank you all this is perfect! I will make a start on them now!
