Distributor Problems
electrical engine
4 replies to this topic
#1 A1111j
A1111j
  • 77 posts
Posted 10 August 2020 - 08:58 PM
hi guys I'm having a problems with my distrobutor from what I can see its a aldon distrobutor with electronic igition without vacuum with bosche blue sports coil. I am burning distributor caps and arms. I cannot find anywhere on line what the problem could be. i was wonder if anyone here know. I have had multiple makes of caps and arms but still the same problem
#2 Spider
  • 14,613 posts
Posted 10 August 2020 - 09:13 PM
The issue here isn't from the Cap and Button.
There's so much advance in the distributor that it's firing well before the rotor lines up with the contact in the cap, that's why the burning is on the leading side of them.
I'd say, that either the magnet on the shaft isn't as well lined up (or aligned) as it could be and / or the Pick-up itself isn't in the most ideal location.
Another fix here is to find a Rotor Button for a 45D4 from a Distributor that spins in a Clockwise direction.
#3 A1111j
A1111j
  • 77 posts
Posted 11 August 2020 - 11:25 AM
Thanks for that iv had a look cannot find one that spins clockwise on a 45d4.
#4 Spider
  • 14,613 posts
Posted 11 August 2020 - 07:18 PM
I'd suggest having a good long look at how the electronic kit has been fitted up and in particular, the magnet that fitted to the shaft, I suspect there's an issue somewhere in there.
#5 richmondclassicsnorthwales
  • 942 posts
Posted 12 August 2020 - 01:10 PM
Have to agree with Moke - lots of advance on that - and the cap shows the problem really clearly
You could try a DRB104C rotor arm, this arm is more of a straight sweep instead of the right handed sweeper arm you have in.
If someone suggests using a DRB106 - don't - as this arm is to big and will chew the cap, but is a left handed sweeper rotor
Also tagged with one or more of these keywords: electrical, engine
