This is what I know about the car it has a 1275 head with weber dcoe40 and Kent cam 544.
Posted 09 August 2020 - 12:36 PM
Posted 09 August 2020 - 12:49 PM
is there anything stamped on the end of the camshaft?
ok 544 16 thou
Edited by nicklouse, 09 August 2020 - 12:52 PM.
Posted 09 August 2020 - 12:55 PM
Posted 09 August 2020 - 05:46 PM
Think it is a Kent ‘Silent Chain’ set up - as far as I know they’re now NLA for the A series
Posted 09 August 2020 - 06:00 PM
The gear set does look like my Kent set up. But without the chain.
Posted 10 August 2020 - 04:01 PM
Posted 10 August 2020 - 04:32 PM
The original BMC Special Tuning data sheet gave the valve clearances as 12 thou for the 544. I have set that when I have used a 544 with no issues.
Posted 10 August 2020 - 05:25 PM
Posted 10 August 2020 - 07:08 PM
You’d normally increase the clearance for higher ratio rockers:
12 thou / 1.2 * 1.5 = 15 thou. (not perfect as the standard rockers aren’t exactly 1.2:1)
However we are ASSUMING that you roller tip rockers are 1.5:1 ratio - chances are they are, in fact they look like early MED ones.
Posted 10 August 2020 - 09:46 PM
the lift of the rockers nmakes no real difference as the gap it there to ensure that as the valves expand due to the heat, there will still be a gap so that the valves will always close.
The only other thing is that the tighter the valve gap the longer the valves stay open. It is only a slight amount and most people ignore it.
On my 1275 'S' I have a 286 cam and 1.5 rockers and I set to 12 thou. Never had any issues.
Can You Help Me Guys With My Hs4Started by Notwabel , 26 Dec 2024 engine |
Clutch Not DisengagingStarted by Sharks , 15 Dec 2024 engine |
Possible Transmission Problem?Started by aguiloco , 07 Dec 2024 engine |
Crud In Combustion Chamber.Started by Rubbershorts , 16 Nov 2024 engine |
Full Rebuild MethodologyStarted by PeteD , 16 Nov 2024 engine, electrical |
