Engine Questions
engine
9 replies to this topic
#1 A1111j
A1111j
  • 77 posts
Posted 09 August 2020 - 12:36 PM
Hi everyone I have recently bought a 1971 mini. I have noticed I have roller rockers on the car and then had a look at the timing chain setup and I cant find anything like it online. I was wonder if you guys can help me with this and if some one can advice me on what my valve clearances should be? I am going to attach the photos iv taken.
This is what I know about the car it has a 1275 head with weber dcoe40 and Kent cam 544.
#2 nicklouse
  • 18,366 posts
Posted 09 August 2020 - 12:49 PM
is there anything stamped on the end of the camshaft?
ok 544  16 thou
Edited by nicklouse, 09 August 2020 - 12:52 PM.
#3 imack
imack
  • 2,014 posts
Posted 09 August 2020 - 12:55 PM
I've not seen a multi plate chain and timing gear on an A series before. Nice.
#4 GraemeC
GraemeC
  • 7,418 posts
Posted 09 August 2020 - 05:46 PM
Think it is a Kent ‘Silent Chain’ set up - as far as I know they’re now NLA for the A series
#5 nicklouse
  • 18,366 posts
Posted 09 August 2020 - 06:00 PM
The gear set does look like my Kent set up. But without the chain.
#6 A1111j
A1111j
  • 77 posts
Posted 10 August 2020 - 04:01 PM
Thanks guys is that 16thou inlet and exhaust?
#7 Cooperman
  • 23,183 posts
Posted 10 August 2020 - 04:32 PM
The original BMC Special Tuning data sheet gave the valve clearances as 12 thou for the 544. I have set that when I have used a 544 with no issues.
#8 A1111j
A1111j
  • 77 posts
Posted 10 August 2020 - 05:25 PM
Is that with the roller rockers or it doesn't make a difference?
#9 GraemeC
GraemeC
  • 7,418 posts
Posted 10 August 2020 - 07:08 PM
You’d normally increase the clearance for higher ratio rockers:
12 thou / 1.2 * 1.5 = 15 thou.   (not perfect as the standard rockers aren’t exactly 1.2:1)
However we are ASSUMING that you roller tip rockers are 1.5:1 ratio - chances are they are, in fact they look like early MED ones.
#10 Cooperman
  • 23,183 posts
Posted 10 August 2020 - 09:46 PM
the lift of the rockers nmakes no real difference as the gap it there to ensure that as the valves expand due to the heat, there will still be a gap so that the valves will always close.
The only other thing is that the tighter the valve gap the longer the valves stay open. It is only a slight amount and most people ignore it.
On my 1275 'S' I have a 286 cam and 1.5 rockers and I set to 12 thou. Never had any issues.
