Hi;
I have a couple of threads in the Gearbox Casing (Transfer Case Side) that have been bodged with UNF bolts.
Following advice I bought a Chronos 5/16x18 Helicoil Thread Repair Kit.
I have drilled out the old threads using the supplied HSS Drill, but the supplied Tap seems way too big (the taper end is bigger than the drilled hole).
The drill is stamped 21/64 HSS and the Tap is stamped STI3/8-16 HSS.
Is the Tap too big and what size Tap should be used?
The Helicoils are also just under 10mm making them a 1D Helicoil, the threaded hole is 23mm deep, should I be using longer Helicoils? Should the Helicoil sit flush with the top of the drilled hole and should I be using Thread Lock when inserting the Helicoils.
Also two of the holes are blind and one is through so should I have a bottoming of plug tap?
Sorry lots of questions
