Expansion Tank For Spi
14 replies to this topic
#1 I hate Brian
I hate Brian
  • 782 posts
Posted 30 July 2020 - 08:30 AM
Hi is the SPI expansion tank still needed if I'm converting to a carb setup ?
#2 sonscar
sonscar
  • 2,995 posts
Posted 30 July 2020 - 08:53 AM
Radiator tank?.I would think so.Steve..
#3 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 30 July 2020 - 10:09 AM
I'd keep it as it's handy if the radiator cap or thermostat fail.
#4 MikeRotherham
MikeRotherham
  • 976 posts
Posted 30 July 2020 - 11:38 AM
I've got a '94 car with HIF38 carburettor and that has the expansion tank.
#5 goudoogje
goudoogje
  • 94 posts
Posted 30 July 2020 - 01:26 PM
This has nothing todo with the SPI setup, later carb cars had this expansion tank to, just at another location.
I say keep.
#6 viz139
viz139
  • 666 posts
  • Local Club: Irish Mini Owners Club
Posted 31 July 2020 - 11:47 AM
My '96 Spi and my Brothers '92 and '94 carb have the same location under the left wing.
#7 I hate Brian
I hate Brian
  • 782 posts
Posted 31 July 2020 - 12:11 PM
Cheers for the replies but no-one has really given a definitive answer regarding if its necessary or not
#8 sonscar
sonscar
  • 2,995 posts
Posted 31 July 2020 - 12:39 PM
If you want you'r radiator to constantly empty then no,if you like you'r water in the radiator yes.Not quite so simple as this but very close.Mini did not fit it because they thought it was attractive.Even Vizard mentions that some a series empty their radiator and fitting an expansion tank cures it.I would keep it.Steve...
#9 viz139
viz139
  • 666 posts
Posted 31 July 2020 - 12:50 PM
Drive like Miss Daisy and you will be fine. Take the mini for a dash up the mountains in summer with one eye on the road and one on the temperature gauge you may be fine. Rover spent millions on the mini and they thought it should be there so that's good enough for me.
#10 gazza82
gazza82
  • 3,012 posts
  • Local Club: TMF+
Posted 31 July 2020 - 01:14 PM
On some cars the expansion tank has the pressure cap and the one on the rad was simply to stop the coolant coming out .. not sure how it works on and SPi but it that is the way they the rad cap will need to be changed for a pressure cap .. but the rad might not be suitable. Personally if the expansion tank works - leave it. Otherwise when the coolant expands it just ends up on the road ..
#11 I hate Brian
I hate Brian
  • 782 posts
Posted 31 July 2020 - 06:10 PM
okay gents I will refit the tank cheers for all the comments much appreciated
#12 MikeRotherham
MikeRotherham
  • 976 posts
Posted 02 August 2020 - 07:31 AM
As Gazza previously mentioned about the radiator cap. If you did decide to delete the expansion tank you would need to use the appropriate cap.
The expansion vessel isn't pressurised like the MPI version.
#13 Norfolk Boy
Norfolk Boy
  • Just Joined
  • 130 posts
Posted 02 August 2020 - 09:40 AM
I have a 94 hif38 carb model it hasn’t got an expansion tank but does have the carbon canister under the passenger side wing should it have a radiator expansion tank??
#14 viz139
viz139
  • 666 posts
Posted 02 August 2020 - 11:44 AM
Yes it should.
The Rad cap used on minis 92-96 is different to others. It has Two rubber seals  , the one at the bottom seals the rad to allow it to pressurize to 1 bar .on heating up Water passing this seal will enter the expansion bottle. When cooling the seal at the top of the cap prevents air being drawn in and so water is sucked back into the rad from the expansion tank. There is never air in the top of the rad like earlier minis. When fitting the expansion tank half fill it with coolant.
#15 Norfolk Boy
Norfolk Boy
  • Just Joined
  • 130 posts
Posted 02 August 2020 - 12:48 PM
Yes it should.
Thanks for that I’ve had the car for 4 years and never had a problem but I’ll try and get one and suss our where it goes ?
