Different Rates Rubber Cones
19 replies to this topic
#16 unburntfuelinthemorning
  • 2,003 posts
Posted 02 August 2020 - 07:31 PM
How will you get rid off the understeer?
Hopefully a combination of going a tad lower on the front and adding some negative camber will do the trick.  It'll always understeer under power (only really a problem in the wet) but that's controllable on the throttle.  Just want to make it understeer less when turning in.
#17 IronmanG
IronmanG
  • 1,363 posts
  • Local Club: Box hill. Lsmoc member
Posted 02 August 2020 - 08:21 PM
I have a nice mix of cones to try on my Pup. 2 Avon MSpeed ones. 2 mini spares standard and 2 red dot to go with hi los and KYB gas adjust.
#18 IronmanG
IronmanG
  • 1,363 posts
Posted 04 August 2020 - 07:16 PM
3 different cones....
Red spot
Standard mini spares
Standard mini sports avon
#19 RustyAutoCityE
RustyAutoCityE
  • 320 posts
Posted 04 August 2020 - 07:20 PM
What set are you planning to try out first?
I have a set of the Minispares standard to fit when the rear of the car (eventually) goes back together.
#20 IronmanG
IronmanG
  • 1,363 posts
Posted 04 August 2020 - 07:56 PM
Got the back subframe back today from the blasters all primed so need to put a couple of coats on that and go from there I was actually thinking the Avon ones first. They are a fraction longer than standards but feel slightly softer with a squeeze test
