Mike's Cg10 Engine Swap
69 replies to this topic
#46 M J W J
M J W J
  • 976 posts
  • Local Club: not yet
Posted 24 December 2021 - 07:07 PM
This episode has been 10 months in the making but finally I got the drive shafts made.
Here is part 1.
#47 M J W J
M J W J
  • 976 posts
Posted 13 February 2022 - 07:30 PM
Later that expected due to (ongoing) internet issues, but here is part 2 of the driveshafts
#48 McMini 22
McMini 22
  • 289 posts
Posted 24 February 2022 - 02:53 AM
Driveshafts were a job I was dreading. Did mine slightly different.
Cut the shafts with one 10mm longer. Turned a pin on one side and a hole in the other to press fit together. This keeps the concentricity. Left a large v to weld up.
Tacked it then check run out on lathe. Welded up the V and then skim it back to slide a sleeve over and then weld the sleeve.
Kept checking the runout at every stage and they ended up pretty spot on.
This way there are 3 welds holding the shafts together.
#49 M J W J
M J W J
  • 976 posts
Posted 29 May 2022 - 07:12 PM
Everyone's worst nightmare...wiring
Hopefully there shouldn't be such a long wait until the next episode and I should have some videos coming out that are about something else.
#50 Maccmike8
Maccmike8
  • 1,101 posts
Posted 29 May 2022 - 07:13 PM
The screen shot looks like youve got a mullet with the wiring over your shoulders  :D
#51 Steve220
Steve220
  • 5,040 posts
  • Local Club: BMC
Posted 30 May 2022 - 09:14 AM
Chap, just binge watched your series, and you're local! Great work!!!
#52 McMini 22
McMini 22
  • 289 posts
Posted 30 May 2022 - 09:59 PM
Nice work. Wiring was one of the jobs I was dreading and if I was doing it again I'd use the micra fuse box.
If you are on the micra engine mini facebook group there are .pdf files for wiring diagrams (and more) that have lots more information than the Haynes manual.
#53 M J W J
M J W J
  • 976 posts
Posted 17 August 2022 - 09:57 AM
Sorry I'm a few days late posting the video here but I'm currently in Denmark. Anyway, here is part 2 of the wiring.
#54 M J W J
M J W J
  • 976 posts
Posted 16 October 2022 - 06:33 PM
Right. Its time to start tackling all those annoying little jobs that have got to be done in order to turn this from a never ending project, into a working car.
#55 M J W J
M J W J
  • 976 posts
Posted 14 November 2022 - 11:14 PM
New episode should be out this weekend. Until then, I decided to print a more accurate and up to date sticker for my fuse panel.
#56 M J W J
M J W J
  • 976 posts
Posted 18 November 2022 - 08:07 PM
The wiring is finally complete!!!
#57 M J W J
M J W J
  • 976 posts
Posted 10 December 2022 - 03:04 PM
Ah the joys of YouTube...
New episode should have been released tonight but unfortunately during the upload process I got copyright claimed so there will be a slight delay while I sort it out.
It appears a piece of music I used from a copyright free source, uses a sample from another track which someone claims (the track in the above image is the sample and not the actual track I used). While YouTube says that the owner gives permission and that there will be no issue, I noticed who was making the claim and have no desired in dealing with them again.
Hopefully I should be able to re-edit the episode and upload load it again, ready for tomorrow evening.
#58 M J W J
M J W J
  • 976 posts
Posted 11 December 2022 - 11:00 PM
In this episode I prep the engine bay ready for when the engine goes back in.
Edited by M J W J, 11 December 2022 - 11:02 PM.
#59 M J W J
M J W J
  • 976 posts
Posted 18 December 2022 - 10:20 PM
In case people were wondering, typically an episode takes about 4 weeks to make. I've attempted to make the next one in about 12 days
(lots of late nights and early mornings O_O).
Fingers crossed it should be out Friday.
#60 M J W J
M J W J
  • 976 posts
Posted 24 December 2022 - 10:09 AM
Last episode of the year. Don't worry though there is still more to come and work is still progressing on the Mini.
