But the listing said 'bolt on'
Inlet/exhaust Manifolds Not Level With Washer/bolt.
Harwoods
, Jul 19 2020 06:18 PM
engine
17 replies to this topic
#16
Posted 22 July 2020 - 11:26 PM
#17
Posted 23 July 2020 - 12:25 AM
Hi friend! I had the same problem and solved it with this.
Don't be afraid, you just need to have a good pulse, work in good light and file between 1mm and 1.5mm. When both surfaces are at the same height, place a solid thick washer (12A1211) that Minispares sells.
Good luck
Good luck
#18
Posted 23 July 2020 - 07:46 AM
It does bolt on - they just forgot to tell you that you'll need to mess about for it to work with the other components that you need to fit too!
Mini Technical Sections →
Problems, Questions and Technical →
‘93 Spi Downpipe ReplacementStarted by ShabbyMini , 03 Apr 2025 ![]() |
93 Italian Job Wont StartStarted by Mattnumber2 , 28 Mar 2025 ![]() |
NewbieStarted by adenton , 23 Mar 2025 ![]() |
Tips On Buy An Used Su Hs4 CarbStarted by hfolguera , 17 Mar 2025 ![]() |
Engine Has Been Sat 10 YearsStarted by JHN_mini , 15 Mar 2025 ![]() |
