Fuel Hose Warning
18 replies to this topic
#1 dsgoody
dsgoody
  • 519 posts
  • Local Club: Gert Lush Minis
Posted 19 July 2020 - 11:54 AM
I had an issue a few weeks ago where fuel was leaking from the inlet of my carb and down onto the exhaust manifold. Had I have not caught the issue it could have caused a fire. It’s highlighted the importance of correct size fuel hose; so I’m going to leave this information here to hopefully help some people out. I'd advise anybody to go out and check their fuel hose and make sure it is secure and fluid tight.
I’ve taken a lot of influence from here; http://www.volksbolt...aq/fuelhose.htm so please credit these guys for a very helpful resource.
Correct I/D Sizing
Most Mini suppliers will sell you 1/4” (6.35mm) internal diameter (I/D) fuel hose. This is perfectly suitable for beaded 1/4” inlets however on measuring up the inlets on my original HF38 carb, original fuel pump and current HIF44 carb what did I find;
They are all 6mm! Ideally, a rubber fuel hose should be stretched slightly over the pipe to form a fluid tight seal; so a slightly smaller 5.5/5.6mm I/D pipe should be used to ensure a fluid tight seal. On a pipe that has beaded ends a 6mm I/D pipe could be used safely as it’s stretched over the bead (in my opinion), but a 5.5/5.6mm hose would offer a better seal.
My HIF44 carb not having a beaded end; I should have been using a 5.5mm I/D hose and not the supplied 1/4" (6.35mm) hose. After a few years of wear it stopped gripping the pipe and started leaking fuel; so much so that even with the supplied clamp fully tightened I could just pull it off the carb with no force at all. I've replaced it with this smaller (and Ethanol proof) hose;
https://imgur.com/aqRkMQm (old on left; new on right)
Correct Hose Clip Sizing
Another issue I encountered was incorrect clip sizing;
This 1/4” hose has an outside diameter (O/D) of 12mm; but the supplied clips were 13 to 15mm. A clip of 11 to 13mm should have been used; allowing adequate and mostly even clamping force onto the pipe.
For reference I replaced all my fuel hoses with this;
Cohline 2240 5.5mm I/D with 10 to 12mm clips
Cohline 2240 7.3mm I/D with 12 to 14mm clips (for my 8mm tank feed on HIF38 cars)
This was my personal choice for peace of mind; but there are perfectly suitable cheaper options out there.
Edited by dsgoody, 19 July 2020 - 03:42 PM.
#2 DB1380
DB1380
  • Just Joined
  • 55 posts
Posted 19 July 2020 - 12:58 PM
Yes to this above.
Im not a great fan of Braided Hoses either....hard to see splits or wear.
Ive seen one or two Aircooled VDubs go up in smoke due to crap fitting fuel lines. Them Campers do burn well !!
#3 pltudinous
pltudinous
  • 33 posts
Posted 19 July 2020 - 02:03 PM
I've just discovered that my overflow pipe aims at the exhaust, so I'm achieving this a different way, but cheap fuel lines are definitely scary! Couldn't imagine losing the car to something as simple as cheap fuel line
#4 mab01uk
mab01uk
  • 12,412 posts
Posted 19 July 2020 - 02:42 PM
Minispares - Orange band denotes - Made to specification to cope with modern ethanol based petrol:-
http://www.minispare...assic/PPK7.aspx
GENUINE SU HS STAYUP FLOAT KIT
The new adjustable height StayUp® Float is resistant to modern ethanol Based Fuels and has a military spec closed cell construction making it puncture proof.
http://www.minispare...00.aspx|Back to
Edited by mab01uk, 19 July 2020 - 02:46 PM.
#5 I hate Brian
I hate Brian
  • 782 posts
Posted 19 July 2020 - 03:04 PM
Very helpful thanks for the info  :highfive:
#6 dsgoody
dsgoody
  • 519 posts
Posted 19 July 2020 - 03:40 PM
Nor could I; glad I caught it before it could have become a problem. I have a pipe on mine from the overflow, that joins to a steel line and takes the float vent away over the top of the clutch and down the front of the engine.
While I agree replacing components with Ethanol proof variants is a good idea; the issue in my case was the use of 1/4" fuel line and it not being appropriate for every Mini (certaintly wasn't for mine).
#7 I hate Brian
I hate Brian
  • 782 posts
Posted 19 July 2020 - 04:12 PM
So what fuel lin did you have originally ? I'm using an existing SPI pipe to feed my hif 44
#8 Vanman20
Vanman20
  • 274 posts
Posted 25 July 2024 - 10:09 AM
Holy thread revival.
I had an issue a while back where the rubber hose from the tank to the fuel pump was so loose it came off !
I replaced it with a new length of 1/4" and new clamps.I also replaced the pump to carb hose with a Minimine supplied braided hose.
Just been doing some checks and both are loose on the fuel pump !
#9 sonscar
sonscar
  • 2,995 posts
Posted 25 July 2024 - 10:23 AM
Might not be the case but often overlooked is the need to use properly sized fuel hose clamps.The hose clamp style are poor at fitting smaller diameter pipes.Steve..
#10 PoolGuy
PoolGuy
  • 848 posts
Posted 25 July 2024 - 12:01 PM
As Steve points out above, I certainly wouldn't use the Jubilee clips referenced in the OP, properly sized fuel hose clips are essential IMO https://www.merlinmo...-5-16mm-sfhc-15 don't assume that this clip in my link is the correct size for you, but they are the correct style of clip.
#11 Vanman20
Vanman20
  • 274 posts
Posted 25 July 2024 - 12:22 PM
I have those style clamps and in the correct size.Even tightened up the hose can still be turned
#12 68+86auto
68+86auto
  • 899 posts
  • Local Club: Queensland Mini Car Club
Posted 25 July 2024 - 10:20 PM
Then you have the wrong size of hose. The correct one should be difficult to turn without a clamp.
#13 Vanman20
Vanman20
  • 274 posts
Posted 26 July 2024 - 03:54 PM
I take it you didn't read my earlier post,the hoses WERE tight when installed,they aren't tight now and won't go any tighter, I have now bought some 5.5mm ID hose which should hopefully fix the issue permanently
Edited by Vanman20, 26 July 2024 - 03:57 PM.
#14 PoolGuy
PoolGuy
  • 848 posts
Posted 26 July 2024 - 04:39 PM
If you’re going to get grumpy with people, at least get your story straight.
#15 gazza82
gazza82
  • 3,012 posts
  • Local Club: TMF+
Posted 26 July 2024 - 05:42 PM
That's probably down to the nice ethanol carp they add that has softened the rubber hose .. which may not be ethanol resistant ...
