E Coat / Cataphoretic Coat V Epoxy Primer
Posted 13 July 2020 - 10:37 PM
I originally planned to paint everything in epoxy primer but wondering if this would be any benefit compared to the e coat on there already?
Does anyone have experience with rhibo's e coat?
Would epoxy be better than this e coat in the long run?
Cheers!
Posted 15 July 2020 - 02:32 AM
A good epoxy properly applied will beat a good e-coat in almost all circumstances. For one thing, the epoxy is a better surface for following layers of primer and paint to grip to.
If the e-coat is a good quality one and there are no rust tracks in it, you can scuff and coat it in epoxy, which will give good results. You can get good durability with e-coat alone if it is of high quality, but for sure, if a panel is hard to replace, I'd give it an epoxy coat for the best chance of longevity.
I have no experience with rhibo.
Dave
Posted 15 July 2020 - 12:19 PM
I have the rhibo front end, be interested in how yours fit if you get there before me!
Posted 15 July 2020 - 01:49 PM
I'm always sceptical about any of the coatings we get on our panels whether its heritage magnum or whomever. I remove them all, period!!
Oh and epoxy prime or Octoral P131 Surfacer if you are painting straight away.
Posted 15 July 2020 - 06:17 PM
I cant comment on rhibo panels, as i only use heritage ones. However, i have had some pretty poor e coat on them too, from grease under the e coat to rust spiders and poor adhesion. I can agree with sonikk that the safest is to remove it and epoxy the panel (irrespective of supplier), but with some large complicated panels it would be a horrendously time consuming job.
I generally do 3 things. First a general once over of the appearance of the quality of the e coat finish. If thats ok, i (2) run the DA over the whole panel to see if any anomalies turn up. If all looks good i (3) scratch a few places and give the area the good news with the air line to see if it lifts. If it flakes off i remove all the e coat, if it doesnt i leave it as is and epoxy over the DA'd surface once its been welded in.
Andy
Posted 15 July 2020 - 09:33 PM
@PiG I will update on how these fit. I've seen one post on these fitting very well. They're supplied via M-Machine as repro units.
I'm pretty impressed by them so far, for the price and coming with e-coat,I don't think you could complain, though I haven't tried to line it up yet!
Posted 15 July 2020 - 09:34 PM
