Swiftune Csi Distributor: Correct Curve Setting For Kent Cam 276
22 replies to this topic
#1 spence1380cc
spence1380cc
    Just On Tickover
  • 8 posts
Posted 13 July 2020 - 02:51 PM
Hi
Looking for the correct curve settings on a csi dizzy for my 1380cc A+
I've got it booked in to a rolling road and wanted to make sure they have the correct settings
Spec:
1380cc
Weber 45
Big valve TCK Head
1.5 roller rockers
NGK B8ES
276 cam
sccr box 3.1
Thanks in advance.
Spence
Edited by spence1380cc, 13 July 2020 - 03:11 PM.
#2 croc7
croc7
  • 809 posts
Posted 13 July 2020 - 07:49 PM
What I did when installing the Swiftune CSI was to consult the spec sheet that was supplied with the dizzy.  That will get you close.  Changing the curve is a simple task of removing the cap and adjusting with a small flat tipped screwdriver, also nicely provided with the distributor.
#3 spence1380cc
spence1380cc
    Just On Tickover
  • 8 posts
Posted 14 July 2020 - 07:08 PM
thanks, i got it delivered today and see the setting sheet provided. not sure on setting as track or road with my spec engine. think i'll call swiftune tomorrow
#4 Spider
  • 14,848 posts
Posted 14 July 2020 - 08:18 PM
I saw your post yesterday and then went looking for Swiftune's Curves as they are different to the standard ones CSI offer, but while Swiftune's products are good, they are a bit too 'Secret Society' to the point of being silly with too much of their stuff and these, like their cam specs, don't seem to be available.
#5 Midas Mk1
Midas Mk1
  • 5,777 posts
  • Local Club: S.U.N.M.C
Posted 14 July 2020 - 09:46 PM
Try 7's, 8's might be cold, run 7's on mine pretty much same spec bar carb & aldon dizzy.
#6 spence1380cc
spence1380cc
    Just On Tickover
  • 8 posts
Posted 15 July 2020 - 12:20 PM
I have the curves on pdf moke spider think i can only share them on a mail though.
I was running 6's but they kept braking down causing back firing so went to 8's as that's what was recommended by swifttune. think i'll just get it set up on the rolling road and go off they say
#7 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 15 July 2020 - 02:25 PM
Try a set of 7 rated plugs, a little bit of a closer match
#8 Minigman
Minigman
  • 779 posts
Posted 16 July 2020 - 07:13 PM
I’m running near enough the same spec as you expect with twin 1.5 SUs. I’m currently got mine set at 16. No idea if this is right or not, but the road curves ar 13-16. I can take a pic of the sheet supplied if you need it. Mine is the Swiftune 23D dizzy though so no idea if that makes any difference?
#9 Spider
  • 14,848 posts
Posted 16 July 2020 - 08:05 PM
If your CSI is the one that Swiftune sell, if you could upload a scan or photo of the curves, that would be helpful. The Curves are all the same between the body types.
#10 nicklouse
  • 18,583 posts
Posted 16 July 2020 - 09:43 PM
You should be able to attach a pdf to any post.
#11 Minigman
Minigman
  • 779 posts
Posted 17 July 2020 - 09:57 AM
Will try and scan ASAP. I’m the mean time here’s two photos covering the four graphs they show.
#12 Minigman
Minigman
  • 779 posts
Posted 17 July 2020 - 10:03 AM
On the basis I’m too thick to work out how to actually attach the PDF. Maybe an apple thing...
Edited by Minigman, 17 July 2020 - 10:33 AM.
#13 nicklouse
  • 18,583 posts
Posted 17 July 2020 - 10:06 AM
you can attach PDFs to posts you know.
Attached File  04-28-2020 German Traffic Code amendment.pdf   750.93K   31 downloads
some boring German road rule changes for you.
#14 Minigman
Minigman
  • 779 posts
Posted 17 July 2020 - 10:27 AM
Done now I think.
Edited by Minigman, 17 July 2020 - 10:34 AM.
#15 Minigman
Minigman
  • 779 posts
Posted 17 July 2020 - 10:32 AM
Here we go fingers crossed.
Edited by Minigman, 17 July 2020 - 10:47 AM.
