Rubber On Clubman Front Catch Panel
13 replies to this topic
#1 Vinay-RS
Vinay-RS
  • 2,114 posts
Posted 13 July 2020 - 10:16 AM
Hi everyone,
My Clubman has a strip of rubber on the front catch panel and I figured it was there to reduce any possible rattling of the bonnet. I was wondering if this was standard and if anyone else had any pics of something similar fitted to their cars?
Thanks,
Vinay
#2 colinf1
colinf1
  • 1,013 posts
Posted 13 July 2020 - 11:59 AM
There wasn't any rubber on my clubman...I'd say someone has put it there to reduce the possible rattle as you said
#3 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 13 July 2020 - 12:25 PM
The only rubber i had on my clubby were the two bonnet stops, one each side and thats it.
#4 Vinay-RS
Vinay-RS
  • 2,114 posts
Posted 13 July 2020 - 02:53 PM
Thanks! Yeah, then it was probably exactly that. It seems to do the job quite well and doesn't look unsightly.
#5 JXC Mini GT
JXC Mini GT
  • 841 posts
Posted 13 July 2020 - 03:52 PM
I have a rubber strip fitted to mine, it seems to stop any rattles from the bonnet?
https://i.imgur.com/c3gQzBv.jpg
Edited by JXC Mini GT, 13 July 2020 - 03:53 PM.
#6 Spider
  • 14,821 posts
Posted 13 July 2020 - 07:20 PM
Our Local Clubmans had a rubber weather strip that was fitted to the engine bay side of the lower windscreen panel, in the same place as JXC's above.
No. 30 in this diagram
This may have only been fitted to the Australian produced cars ?
The Rubber section had a U section to clip over the metal edge of the panel and also a high raised lip that would contact the underside of the bonnet when it was closed.
#7 Mini Manannán
Mini Manannán
  • 2,856 posts
  • Local Club: man Estate
Posted 13 July 2020 - 08:08 PM
Do you mean one of these?: http://www.minispare...ic/JRC7898.aspx
#8 Mini Manannán
Mini Manannán
  • 2,856 posts
Posted 13 July 2020 - 08:12 PM
I think JXC's is this one?: http://www.minispare...c/JRC8000.aspx.
I intend to fit both before winter
#9 Vinay-RS
Vinay-RS
  • 2,114 posts
Posted 14 July 2020 - 03:16 PM
Thanks! The one on my car is actually just a strip of rubber on the catch panel. This strip seems more useful. Looks like these two part numbers would be worth getting?
http://www.minispare...98.aspx|Back to
Not sure where this would go?
http://www.minispare...ic/JRC8000.aspx
or this?
http://www.minispare.../14A9010MS.aspx
I would think I would need one for the front of the bonnet (which might be there) and one on the rear? Does there need to be a rubber piece on the body and one one the bonnet on either side?
#10 Chris1275gt
Chris1275gt
  • 937 posts
Posted 14 July 2020 - 05:04 PM
or this?
The jrc7008 rear seal did not fit my 75 clubman by a camel ride and lifted the rear of the bonnet 5mm. After measuring the gap at the back with the bonnet closed I found this on eBay and it fitted perfectly.
https://www.ebay.co....353.m2749.l2648
#11 Vinay-RS
Vinay-RS
  • 2,114 posts
Posted 15 July 2020 - 06:44 AM
or this?
Thank you :) I will remove the MS part from my cart. I should check if I can find something locally with the same profile.
#12 spraybeater
spraybeater
  • 468 posts
  • Local Club: Mcr
Posted 15 July 2020 - 08:58 AM
Here is a photo of both fitted to my Contessa! neither prevent the bonnet from closing properly.
Having said that I started doing bodywork on minis in 1962 HaHa!
I use Minispares for more or less all my parts, back in the day when we could source factory parts
inc Special/Tuning parts was a different world.
#13 Mini Manannán
Mini Manannán
  • 2,856 posts
Posted 15 July 2020 - 08:24 PM
or this?
That listing has ended Chris.  Supposedly the seller has relisted, is this one the right dimensions? https://www.ebay.co....em=333627504896
#14 Chris1275gt
Chris1275gt
  • 937 posts
Posted 15 July 2020 - 09:27 PM
or this?
Yes that's the one that fitted mine. I would measure yours before you order. Measure the scuttle bottom to the top of the bonnet.
