Help Identifying Twin Carbs
engine
11 replies to this topic
#1 chris1212
chris1212
    Just On Tickover
  • 5 posts
Posted 12 July 2020 - 06:02 PM
Hi there, in advance if i am posting this in the wrong category or anything!
I have come across a set of complete carbs in the garage while clearing out.
I am after some advice of what they are off, and if it looks like they are complete?
Also a rough price of what they are worth would also be handy.
Kind Regards in advance.
Chris
#2 timmy850
timmy850
  • 3,291 posts
  • Local Club: MITG
Posted 13 July 2020 - 04:35 AM
They are twin HS2’s with a Mk2 or later manifold and airbox.
A mint condition airbox can sell for mega bucks
Here’s an example of one sold recently
https://www.ebay.co...._app-cvip-panel
#3 richmondclassicsnorthwales
  • 942 posts
Posted 13 July 2020 - 04:57 PM
If you can tell me the letters and numbers on the tags, I can tell you what car they came from, it will possibly start AUD
These were fitted to the late 1300 Austin as well, but if you tell me the numbers and letters, I should be able to help.
#4 chris1212
chris1212
    Just On Tickover
  • 5 posts
Posted 13 July 2020 - 05:01 PM
Thank both for a quick response! When I get home I will clean the tabs up and see what is stamped on them.
#5 chris1212
chris1212
    Just On Tickover
  • 5 posts
Posted 13 July 2020 - 06:40 PM
I've cleaned the tabs up and they are AUD318R & AUD318L.
Thanks chris
#6 nicklouse
  • 18,524 posts
Posted 13 July 2020 - 06:46 PM
TWIN SU 1¼ HS2 Carburettor SERVICE KIT for MG1300 Mk2 1969
Attached File  aud318.JPG   15.83K   3 downloads
Edited by nicklouse, 13 July 2020 - 06:50 PM.
#7 richmondclassicsnorthwales
  • 942 posts
Posted 13 July 2020 - 07:56 PM
Indeed they are !
#8 blacktulip
blacktulip
  • 6,224 posts
Posted 13 July 2020 - 08:18 PM
If you give them a thorough clean and are working then you should fetch over £400 for these complete with the airbox. I'm not sure if your airbox snorkel has been cut but it should be longer with an bend at the bottom with a ring and clip.
#9 chris1212
chris1212
    Just On Tickover
  • 5 posts
Posted 14 July 2020 - 06:19 AM
Thank you for the replies I much appreciate it! I did have that feeling when doing a bit of looking around, that the snorkel had been cut down at some point. Do you guys know from the pictures if the carbs look to be all complete? And is there anyways you would recommend to clean them up?
Thanks chris
#10 chris1212
chris1212
    Just On Tickover
  • 5 posts
Posted 14 July 2020 - 06:20 AM
Thanks chris
#11 johnR
johnR
  • 2,295 posts
Posted 14 July 2020 - 07:27 AM
Depends if you mean clean them up or restore them. Burlen in Salisbury for example will restore them but this will probably cost you about what they will then be worth. Unless you want them for your own car I would be tempted to just put them on Ebay as they are - originality is valued these days.
#12 richmondclassicsnorthwales
  • 942 posts
Posted 17 July 2020 - 08:39 PM
Pricey doing the work your self. Believe me, runs into hundreds !
Then you have the negative of people saying the work was inadequate, so let someone else fiddle with them
