Just replaced a torn steering gaitor.
I cannot get the track rod end bolt up into the hub again. It lines up well. When I turn the nut on the bolt, it just spins round within the track rod end.
I put trolley jack directly under the track rod end and raised it as far as it would go to try and get the hub to grab the non-threaded tapered part of the bolt that goes through the hub but no joy.
I'm stumped.
Been a good day largely speaking - HiLo's installed (top arm removal was a horrible job). Cone was 2 inches shorter! Changed a CV boot and regreased the bearing. I just can't reassemble that darn tie rod end. I have it all to do again on the passenger side.
Kaz
Edited by Kaz Farooq, 11 July 2020 - 08:06 PM.
