Do we get to see the Land Rover repairs as well?
Mm 1987 Mini Advantage @ Mill Road Garage Iow
#106
Posted 03 October 2020 - 10:29 AM
#107
Posted 03 October 2020 - 04:55 PM
I can always put some photos up on the mill road thread if you would like.
Ben
#108
Posted 04 October 2020 - 08:30 AM
Very neat work as ever Ben.Yes please to the Land Rover pics , what year is it?
#109
Posted 04 October 2020 - 08:46 AM
Hi Ben, quick question; when you spot weld do you clean both flanges to bare metal or do you leave them coated in weld through primer?
#110
Posted 04 October 2020 - 10:00 AM
Thanks.
The land rover is nothing interesting. It's a 2000's defender.
Yes, I always clean back to bare metal and use a weld thru primer between the pieces to be welded.
Ben
#111
Posted 09 October 2020 - 04:47 PM
Back to the advantage this afternoon.
I started by plug welding the front of the floor to the toe board
And then made a start on the right hand step.
With the old one cut away, I could clamp on the new one to check for fit.
These magnum step panels aren't the greatest in finish but they fit well and can be tidied up nicely.
With the door back on, I can check the fit
A frilly door is not the greatest datum but it's good enough to check the gaps.
The next step is to mark the join line with the quarter panel.
The black line is the edge of the new panel and the pencil line is 10mm below.
This is where I will cut the quarter panel.
Once I cut along the pencil line, I joggled the edge up to the black line and cleaned back
Now the new piece can sit in flush and the joggled edge will add rigidity to minimise distortion.
With the cutting in complete, I can clean up and prep the areas.
I just need to cut in the a post up front now and it's ready to fit.
Ben
#112
Posted 13 October 2020 - 12:18 PM
I decided rather than fit the step and quarter bottom as one piece and loose the little seam between, I cut it up and modified the two pieces to retain the factory seam.
Before I weld it all on, I painted inside the cavity and the insides of the new pieces with epoxy.
Next, I clamped the step into place, measured the height of the step and then tacked the joins at the A and B posts
And then once I had trial fitted the door, I spot welded the seams and welded up the joins fully
Just the quarter bottom to go now.
Ben
#113
Posted 13 October 2020 - 02:55 PM
Here is the new quarter bottom clamped and tacked in place
And then spot welded
And then after slowly welding up the join.
Ben
#114
Posted 13 October 2020 - 05:09 PM
On to the other side now.
I'm taking a different approach this side as it needs an a post too
A panel removed
And tomorrow, I shall remove the outer a post and repair the inner ready for the new bits.
Ben
#115
Posted 13 October 2020 - 06:32 PM
It's such a good job I cannot do this. I'd be buying all the sheds on Ebay to do up!! Well jealous Ben
#116
Posted 14 October 2020 - 04:10 PM
First job today was to remove the outer A post.
Just a few spot welds to drill and a cut at the top and its off
It's actually pretty clean in here which is surprising looking at the state of the outer panel.
I removed the inner hinge frame piece anyway so that I could check it and clean the back edge if needs be. It's actually really clean
There are a few areas on the boxing panel that need repairing but not too much
The worst of the rust on the frame piece was around the check strap bracket so I blasted it
And that's ready to go back on.
Here is the boxing panel and flitch cleaned up
The first of the repair pieces for the boxing plate made and ready to weld
And the repairs completed
Hinge frame clamped back in
And then welded
I'm waiting for an outer A post to arrive so I started getting the back end prepared
And ready for the new bits
As soon as the A post arrives, ill get that finished off
Ben
#117
Posted 15 October 2020 - 04:25 PM
Not much time on the advantage today but I got one repair done.
Quite an awkward bugger.
The section with the hole sits under the outer B post so that needs to be cut off carefully
And then I could remove the holes section
And make up a new piece
Weld it in
And then carefully graft the previously removed outer back on, grind up and repair complete
#118
Posted 15 October 2020 - 05:00 PM
#119
Posted 15 October 2020 - 08:02 PM
#120
Posted 16 October 2020 - 08:58 AM
ahhh thats makes the difficult repairs look very easy!!
I'm afraid to start on the A post, I have quite the same rust hole on the door surround. But I first have to move my way frome the last repairs at the back and then go on up to the front...
Thanks for showing your tips and tricks also!
