Mm 1987 Mini Advantage @ Mill Road Garage Iow
464 replies to this topic
#91 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 26 September 2020 - 11:51 AM
Hello Ben
What is the setting on spot welder when you weld three layers together?
Are you asking about the settings for my particular spot welder?
only the settings vary so wildly between machines which is why we must do a peel test before committing to spot welding the whole lot.
Ben
For example there is a particular setting ( timing and force ) for 1+1 mm material.
What do you change to 1+1+1 mm ?
Hope my question is clear now :)
I see now.
My machine has a dial for power/weld time so for 3 layers, I'll take some 0.9mm steel, cut 3 small pieces and clamp them together. Start the machine on 7 and spot weld the layers together. Then I do a peel test. If the test passes, I'll go with that setting, if it fails, I up the power and repeat the test.
It's quite a basic machine so the tests are vital but providing the tests are carried out, there are no problems.
for 2 layers or .9, I'll use the machine on 5 or 6 for example bit really it's the peel test that decides.
As for clamping force, the pliers are pneumatic and the force is not adjustable but I would always make sure all layers to be welded are clamped tightly together during welding and it never fails
Ben
Edited by Ben_O, 26 September 2020 - 11:53 AM.
#92 gaspen
gaspen
  • 1,194 posts
Posted 26 September 2020 - 01:36 PM
Thanks ! I'll make a test with the 1.5+1.5 mm setting.
Attached File  NĂ©vtelen.png   126.83K   1 downloads
Another question if you don't mind : before you spray epoxy to new heritage panels, do you remove the E-coat or just sand a little to help the epoxy to stick?
Bence
#93 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 26 September 2020 - 02:08 PM
Bence
Yep. That's the best way. Power too low means insufficient weld quality and too high will just blow the weld.
As for the e-coat, I sand the larger areas using an orbital sander with P180 grade discs and a red scotchbrite in the tighter areas the sander cant reach.
I usually sand off quite a lot of the e-coat just trying to sand out scratches and scrapes and dirt in the finish
You don't have to go that far though if you don't want to. A scuff up with a scotchbrite is sufficient.
Ben
#94 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 28 September 2020 - 05:10 PM
Not very much achieved today on this as i've been working on something else.
I did manage to make a start cleaning and repairing the toeboard however
I've started the other side which is the same process only a little more to cut out and replace.
Ben
#95 Avtovaz
Avtovaz
  • 1,316 posts
Posted 28 September 2020 - 07:00 PM
looks good mate! The advantage is in rover dimond white, how white looking [i know that sounds daft!] is it? Is it like slightly creamy ? Im not sure my paint has mixed up right and it looks kinda old english white. I seem to remember them looking really bright white, but i cant tell from pics, and i dont know of another to look at. thanks
#96 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 28 September 2020 - 07:08 PM
It's quite a bright white.
I wouldn't say its creamy at all
#97 Avtovaz
Avtovaz
  • 1,316 posts
Posted 28 September 2020 - 07:40 PM
thanks thought so, ive had my paint for 3 years, tried to mix it as best as i could and it is a bit creamy, wasnt sure if it was because i was used to these newer whites used to transits etc.
thanks! keep up the good work, wish i had just given my car to you!
#98 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 30 September 2020 - 05:09 PM
Few bits done today on the Advantage.
I started trial fitting the floor in
It took a while to get everything in the correct position but once it was, I put the subframe in to check the fit
Its perfectly square so i'm happy with that position.
Before removing the floor again to begin prep, I clamped the closers in place both sides so that they can be spot welded to the floor prior to fitting
And then I lifted the floor back out for prep.
More on that next time.
Ben
#99 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 01 October 2020 - 05:59 PM
The closers are now welded into place
And I've removed the airbag ecu bracket
And I've drilled holes in the front of the floor so I can plug weld it to the toe board
I've also drilled holes in the back of the floor and heelboard ready to plug weld the companion bins either side however I forgot to take a picture.
The floor is now ready to go in so I'll do that tomorrow.
Ben
#100 Sam76
Sam76
  • 40 posts
Posted 02 October 2020 - 05:43 AM
Stunning work - as always Ben! Always enjoy your threads you seem to make a very daunting job look like a walk in the park lol ?
#101 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 02 October 2020 - 12:28 PM
Getting closer to having the floor in.
With all the prep done, I lifted the floor into place clamping it as I went.
for some reason though, the back of the floor just wouldn't quite lift high enough onto place causing there to be a very slight gap between the bottom of the companion bins and the floor and also a slight gap one side between the seat base and the heelboard.
It looked as though it was the old crusty twisted steps that were the cause so I had to get creative to enable me to pull the floor up.
This was the result
That's a harness eye bolt screwed into the seatbelt mount, an exhaust clamp and a g clamp to pull up on the bracing.
it worked fine
And the other side
Everything fits lovely
Back in with the subframe to double check alignment
And that's all fine.
Before proceeding, I screwed the floor in at various points just to hold everything firm
And this afternoon, I'll get it welded in.
Ben
#102 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 02 October 2020 - 02:47 PM
The welding has commenced.
I always start at the back doing each operation each side before moving onto the next.
First up is the floor to companion bins
And the other side
Then the closing panel forward of the wheel arch.
it needs to be spot welded to the arch tub
And to the companion bin and seat base
Shell is upside down in that pic with the photo being taken through the bottom of the quarter.
And the other side
And then the subframe comes back out to weld the heelboard to the companion bins and seam weld the closing panel in place as per factory.
You can see in that pic that the closing panel needs to be flush with the boot floor.
First plug weld the heelboard to the companion bins and tack the corners of the closer
And then weld up
Same the other side
I shall come back to plug welding the seat base to the heelboard as that will be easier with the shell off the spit.
Next is the front of the floor to be welded to the toeboard.
Ben
#103 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 02 October 2020 - 04:31 PM
I was talking rubbish earlier.
There was plenty of room to get the spot welded in with the frame in and the car on the spit so I changed plan and welded the seat base to the heelboard.
That's it now for a few days. Ive had to move the Mini into another part of the building to make way for a land rover next week that's had a tree fall on it.
I imagine that ill be back to the Mini Wednesday or Thursday
Ben
#104 jamesquintin
jamesquintin
  • 1,025 posts
Posted 02 October 2020 - 06:14 PM
Disgustingly neat work as always!
#105 JAYSONIC 79 IOW
JAYSONIC 79 IOW
  • 29 posts
Posted 03 October 2020 - 09:30 AM
It’s really coming on now Ben very neat work
    Bing (1)
