Mm 1987 Mini Advantage @ Mill Road Garage Iow
464 replies to this topic
#76 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 22 September 2020 - 08:01 PM
Didn't realise there are two layers of steel for the roof
Do you mean the frame piece that's visable in the second photo?
#77 floormanager
floormanager
  • 681 posts
  • Local Club: Mini Club Sussex
Posted 22 September 2020 - 08:55 PM
The very same Ben
#78 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 22 September 2020 - 09:59 PM
That is part of the internal structure and is called a cantrail.
The back panel has the roof gutter formed to the top of it and this joins to the roof skin.
The top of the window frame joins to the cantrail.
Ben
#79 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 23 September 2020 - 02:34 PM
Back to work on the rear end this afternoon.
Before I fit the new back panel and valance, I want to prep and Epoxy prime inside the boot, rear panel and valance.
These areas are tricky to reach with it all buttoned up and the Epoxy will give great protection against wet and condensation that often builds up in these areas.
First is to scotch up the new bits and give everything else a through flat down and clean.
And then the Epoxy which I have tinted to match the original primer
And not forgetting the valance closers
Once that's dry, I can carry on welding
Ben
#80 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 23 September 2020 - 05:10 PM
With the primer dry, it was time to pop the back panel on.
Always start by lining the top corners up to the roof where it is still rigid and then tease everything into line working down or you risk pulling the back panel out of shape
And always try the boot lid on before welding.
This is a complete panel so you would think its safe as the appeture is fixed but no, it can drag down causing the hinge rail to twist.
This one is fine
I started by adding a few spot welds to secure the floor and back panel together on the bumper seam
And then added the rear valance
And then welded the 3 skins together across the bumper seam
Then the valance ends to the closer
And thats it for today.
Tomorrow, I shall finish the welding on the back panel and then get it on the spit for floor removal!
Ben
#81 Vinay-RS
Vinay-RS
  • 2,114 posts
Posted 23 September 2020 - 05:29 PM
Ben, will it be keeping the mk1 taillights?
#82 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 23 September 2020 - 05:57 PM
Hi vinay.
Yes, it's going to have the mk1 taillights and I will be converting the bootlid to early spec with the hinges number plate.
Ben
#83 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 24 September 2020 - 04:43 PM
Next bit is to spot weld up the rear panel to side panel seams both sides
Then the lock striker
Then around the window frame
And lastly the gutter
And thats the back complete
Time to go on the spit
Nice and crusty underneath
Some goodies fell out whilst rotating the shell
Next job is to remove the complete floor so I made up a basic frame out of 1" box
Belts n braces and all that.
First stage to removing the floor is to locate the spot welds that secure the bottom of the companion bins to the floor
And then Ill need to drill those but time has run out today.
Ben
#84 floormanager
floormanager
  • 681 posts
Posted 24 September 2020 - 07:35 PM
That mini is getting the full Mill Road treatment.  Must be very satisfying to be able to see all that rot and know you have the capabilities to remove it all.  I would freak out if I saw that!
#85 Bdshim
Bdshim
  • Just Joined
  • 196 posts
Posted 24 September 2020 - 09:46 PM
Great work, thanks for taking the time to share ?
#86 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 25 September 2020 - 04:30 PM
On with the floor removal this afternoon.
I went ahead and cut the bulk of the floor out
And that leaves the inner and outer sills to remove
Not much to do here. Just drill the spot welds that hold the companion bin bottoms to the floor, drill the spot welds holding the front tab of the bin to the inner sill, drill the spot welds that secure the back of the companion bin to the heelboard and then cut inbound of the seams to the step with the inner and outer sills
And then after doing the other side, we have this
Just the de-snagging to do now which just involves cleaning up edges and removing snaggy remains starting with the companion bins
And the front of the floor where it overlays the toeboard
Some of the spot welds are hard to find as there is a lot of corrosion here but I drilled what I could find and then started to split the layers to locate the others
Ive managed half so far
Quite a lot of corrosion between the layers but i expect most of it will clean up ok. I may have to make new ends for the toe board however.
More next week
Ben
#87 floormanager
floormanager
  • 681 posts
Posted 25 September 2020 - 06:58 PM
Well that's got rid of the rusty bits! :ohno:
#88 gaspen
gaspen
  • 938 posts
Posted 26 September 2020 - 02:34 AM
Hello Ben
What is the setting on spot welder when you weld three layers together?
#89 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 26 September 2020 - 08:11 AM
Hello Ben
Are you asking about the settings for my particular spot welder?
only the settings vary so wildly between machines which is why we must do a peel test before committing to spot welding the whole lot.
Ben
#90 gaspen
gaspen
  • 938 posts
Posted 26 September 2020 - 09:20 AM
Hello Ben
Ben
For example there is a particular setting ( timing and force ) for 1+1 mm material.
What do you change to 1+1+1 mm ?
Hope my question is clear now :)
